True duals = less torque?
Old Sep 6, 2011 | 10:45 PM
JonW's Avatar
JonW
Default True duals = less torque?
I want to get rid of the catted head pipes on my 2011 Street Glide. I've been reading that some true duals lose torque over the factory headers. Are there any brands of true dual headers (I want to keep my SE mufflers) that do not compromise torque?
Old Sep 6, 2011 | 10:50 PM
j michael's Avatar
j michael
My personal opinion is that you will never know the difference. I like mine I have 107 ft pounds of torque with duals!
Old Sep 7, 2011 | 04:47 AM
Mike's Avatar
Mike
TDs don't always lose torque to the stock system. My experience with Rinehart TDs is that they will make gains across the entire rpm range, compared to the stock headers. I've installed Samson TDs, and the fullsac TD conversion that lost a little off the bottom, but it was a very little, and mostly not noticible once the bike was tuned. I've had nothing but great luck with Rineharts, which is why I run them on my own bike.
Old Sep 7, 2011 | 07:46 AM
grbrown's Avatar
grbrown
My firsthand experience of using TDs is this. With my S&S 107" I got 102HP/103TQ. Changing to a 2-into-1 my numbers changed to 101HP/107TQ. However that is only part of the picture! I gained around 15TQ in the mid-range, so the torque curve is now very flat, but with the TDs there was a slight lift mid-range to the higher numbers. I was very happy with the TDs, but I am even happier with my latest system. The bike is smoother running and pulls easily from remarkably low rpms.
Old Sep 7, 2011 | 08:42 AM
shore's Avatar
shore
It's not that you lose the top #'s, it's the fact you lose several ft lbs in the useable range. Pulling away from a stop is where you notice it or a lower rpm roll on the throttle.
I liked the sound of TD's over loss of TQ.
Old Sep 8, 2011 | 10:13 AM
djl's Avatar
djl
The question is too general. IMHO, true duals work better on larger displacement motors that are pushing more exhaust. Additionally, when you say "true duals" you include all true dual systems and, IMHO again, some are better than others.
The question of whether or not true duals will result in the loss of torque should be couched in the context of the application. A more appropriate question would be, "will true duals result in a loss of torque on my stock/Stage I/Stage II/StageIII/120r/103" motor". Just saying that the answer may very well be different depending on the application.
Old Sep 8, 2011 | 11:02 AM
Northside's Avatar
Northside
True duals sound good and solve heat on the rider and passenger problems. You probably won't feel much, if any difference, over the stock system with the cats. It would probably make the bike a lot nicer to ride.
If you are a big guy, and pack double a lot, and feel you can't afford to lose any low end grunt, bite the bullet and get a 2 into 1. That change will give you plenty of torque right where a bagger needs it. Guys who run 2 into 1's rarely run duals again.
Old Sep 8, 2011 | 12:41 PM
qtrracer's Avatar
qtrracer
I put duals back on, they only lasted about an hour! This was a carbed bike so I tried to get the TQ back by jetting, thats why they stayed on for an hour because I was messing with the carb and when I finally figured out it was running as good as it could, I put the 2-1 back on.
Old Sep 8, 2011 | 01:32 PM
terryrh's Avatar
terryrh
If all else fails, the have the x-pipe for the 2-1-2
Old Sep 8, 2011 | 10:08 PM
N-gin's Avatar
N-gin
True duals do sound good. And look good. But I will never switch out my thunderheader for them.
I heard if your not twisting over 4000 all the time they are not for you. But who cares, bottom line is if they look good to you and sound good you chances are your not going to worry about a few horses.
