Removed 06 Baffel
Old Nov 20, 2006 | 03:39 PM
tgaetto's Avatar
tgaetto
Default Removed 06 Baffel
Has anyone modified their stock bagger pipes? If so how??
Old Nov 20, 2006 | 11:15 PM
Blk06roadking's Avatar
Blk06roadking
6th Gear
Default RE: Removed 06 Baffel
Yes, drilled out the two end plates (front and Back) smaller hole on the right that on the left. I left the catylist in both mufflers and it sounded ok. Better than stock. It did pop a little but no re-map and the plugs looked ok. You do need to make sure your running the 23degree injectors and not the early 8 degree.
Old Nov 20, 2006 | 11:23 PM
tgaetto's Avatar
tgaetto
Thanks!
I was in the shop today and sacraficed one- cut it open to see what was going on. I see that there are two plates at the rear holding the catalyst in and the rest is the perfirated pipe with the plate in the middle. I am actually supprised at how loud they are stock given the design. I am now going to try and find another set and knock out solid peice at the outlet and drill the holes through each and see how they sound. Just playing around.....
meanjean
May 16, 2013 12:38 PM
fireaxxe
Dec 25, 2010 09:29 AM
Double Duece
Oct 13, 2010 08:36 PM
Rhode Warrior
May 21, 2006 09:52 PM
blk06rk
Feb 21, 2006 12:52 PM
