#1) Would a little dab of teflon paste be OK to put on new flat style exhaust gaskets (head side) to help hold them in place while fitting on new pipes?
#2) I read alot about "bungs" to plug up o2 sensor ports. What kind of set up permits the disconnection of 02 sensors?
1. In my experience the pipe gaskets take some persuading to get into the recess, so don't need anything to hold them in place. They are a tight fit in there!
2. I have bungs in my pipes, but that is because I have pipes for a modern bike on an old carb bike, so I don't have O2 sensors. The holes however help setting up on a dyno much easier, which is one reason for buying the pipes. If your bike has O2 sensors, sleep easy and forget about those bungs!
See now I get it......I never put two and two together.
02 sensors are for EFI bikes only......got it. And the reason for Bungs....Thanks !
