Injector Change Difficult???
Old Dec 22, 2011 | 09:43 AM
TXSailor's Avatar
TXSailor
Default Injector Change Difficult???
I want to change out my 8* injectors for the "newer" 25* injectors on my '06 TC88. The "Stealer" will not do it under the "Warranty Recall" that TMC issued. I can get the injectors pretty cheap and I looked at the Service Manual and it does not appear to be a difficult task.
Can i do this w/o pulling the Induction Module (just the injectors and fuel rail)? Service Manual says you don't have to pull the tank, just prop it up.
Any guidance form the more experienced out there?
I know I will have to change the Map/load on the ThunderMax.....
Thanks, D
Old Dec 22, 2011 | 10:32 AM
PHA-Q's Avatar
PHA-Q
I did mine in under an hour, prop tank up, but you have to remove the upper stabilizer to access them.... Make sure you dont mix up the elect connectors front to rear!!!
Old Dec 22, 2011 | 10:48 AM
TXSailor's Avatar
TXSailor
Thanks. I think "book" is 1.1 hours so I know it can't be too bad. I'm not sure what you mean when you mentioned the "upper stabilizer". I'll check the Service Manual to see it that helps.
Did you have to drain the Fuel tank?
D
Old Dec 22, 2011 | 06:00 PM
250REDNECK's Avatar
250REDNECK
If you have nimble fingers you don't have to touch the tank. Take the horn off. take off the air filter, iac and the map sensor and the throttle bodyoff. use a box wrench and a torque bit to take the fuel rail off (disconnect the fuel line). The hardest part is getting the injector connectors hooked back up but it can be done. Took me about 30 min to change them.
Old Dec 23, 2011 | 01:41 PM
TXSailor's Avatar
TXSailor
I doubt my fingers are that "nimble" and I really don't want to have to "unbolt" the throttle body.
The new injectors are "in the mail" so I suspect, i will pull the tank early next week and do the "install" then. Hopefully, it will not take more than an hour or so.
Thanks, D
Old Jan 3, 2012 | 01:42 PM
TXSailor's Avatar
TXSailor
Default Update
Changed the injectors out day after Xmas. Removing the tank provides infinitely easier access and makes the change a snap. Used a hand vacuum pump to pull the fuel out of the tank and then just removed the "jumper hose" on the front to drain any remaining fuel while bike was on side stand.
Gives you a great opportunity to "clean" up the rocker covers, etc. while it is off as well.
The 25 degree injectors are vastly superior to the 8 degree when used with the TMax. Fuel mileage jumped immediately and the map is still being tuned. Idles and starts much better now as well.
Highly recommend the change for anyone who still has the 8's installed and is looking to do some Stage 1 mods.........
D
1ironhead
Dec 7, 2019 08:37 PM
Big Lebowski
Jul 18, 2013 12:54 PM
2009XBones
Jan 7, 2009 01:59 PM
2008FLHP
Jul 21, 2008 04:48 PM
anubisss
Sep 7, 2006 02:00 AM
