Do I need new rockers?
Old Dec 23, 2011 | 12:04 AM
1320str8_liner's Avatar
1320str8_liner
Default Do I need new rockers?
09 SG 19k, miles and I'm about to upgrade to the SE 103 stage4 kit, with heads and heavy springs, so I'm wondering if I should change or upgrade the rockers, or will my oems be fine for the new build?
Old Dec 23, 2011 | 05:25 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
What lift do you have?
Scott
Old Dec 23, 2011 | 05:40 AM
1320str8_liner
The kit comes with the 254e which is .535/.536 lift on the cams
Old Dec 23, 2011 | 07:26 AM
DRAGO'S BIKE WORKS's Avatar
DRAGO'S BIKE WORKS
Former Sponsor
No your stock ones are fine. Just check them to make sure there okay on the end's & bushings lube them up good reinstall and the will work fine.
Old Dec 23, 2011 | 10:38 AM
djl's Avatar
djl
No new rockers. I know the heav springs are part of the kit and many will disagree but the stock beehives should be able to handle that cam without issues. Many running TW555s, SnS 570s and 585s, Tman 555s and 590s with OEM springs. Recently replaced heavy springs in a friends 103 with the OEM beehives to reduce valve train noise and he is happy as a clam. JMHO.
Old Dec 24, 2011 | 06:09 AM
Hillsidecycle.com
Sponsor
No replacements needed, but if you want to throw a twist into that upgrade, S/E offers a 1.725 rocker arm that push another .030" lift on that.
Scott
Old Dec 24, 2011 | 06:54 AM
1320str8_liner
I just realize I looked at it wrong, the kit comes with 259e not 254e cams
hogkrazy
Mar 17, 2012 01:22 PM
clayman
Nov 3, 2011 04:00 AM
msamarah86
Oct 5, 2011 11:19 PM
msamarah86
Oct 5, 2011 11:16 PM
bagger76
Feb 5, 2010 05:25 PM
