Ok, I've decided that I need to back them off. What is the best way to check for leaks?
Thanks for the help guys.
Take a rag and block the end of the muffler. Don't completey seal off the muffler just, just create enough back pressure to "see" any leaks. If nothing is obvious, you're good to go.
Personally, I think you're wasting your time unless you have a leak or you just want to play around. But that is only my opinion, you should do whatever makes you feel comfortable. I have never ever used a torque wrench on exhaust flanges and have never had an issue. In fact, after reading this thread I decided it would be a good time to go out and check the pipes on my bike. A 1/4" drive ratchet, a couple extensions, a 1/2 socket, and a little twist - good as new!
I bet you have never seen an exhaust gasket that has been squished into the port impeding flow. I have so that is why I would take it off. not for the leaks but for the flow obstruction.
The exhaust gaksets have been compressed by the intial torque; particularly if the OEM gaskets. If you back them off and re-torque to a lesser torque, you are inviting leaks. Much smarter move would be to drop the pipes, install a set of the SE stainless steel gaskets that will not compress into the port and retorque to 60-80 in. lb. per spec.
If the exhaust is leaking, you will hear it and the engine will start popping on decel.
I have repeatedly read on this Forum to stay away from the SE gaskets and go with the standard ones. I bought both, got scared away, and kept the stock ones. Also, my dealer who had both types at the same cost said that they did not like the SE...to each his own.
cometic makes a nice crushable metal gasket that works well. It is not like the mesh se gasket. I tried the se on different pipes and some they work in and some they do not.
im sure all that extra money which could had been spent on other things, like chrome, was well spent on a "Professional." im silly, i want to keep as much money as i can and buy stuff for my scoot than put it in some guys pocket for doing a job i can do by reading a bookand taking my time...
