S&S Troubles
Old Jul 25, 2005 | 08:51 PM
JugsReturn's Avatar
JugsReturn
Default S&S Troubles
I have a 1980 Harley Davidson Sportster that has just been restored, but I am having problems with the S&S Super E Carb. Whenever I turn the petcock on gas POURS out of the overflow on the carb. I'm not sure what to do. This is the first restoration I've ever done and need a little help on fixing this problem.
Thanks
Old Jul 25, 2005 | 09:56 PM
71 shovelhead's Avatar
71 shovelhead
Default RE: S&S Troubles
the needle valve in the carb is not sealing, either foreign material on the seat or a damaged needle
Old Jul 25, 2005 | 10:10 PM
FL Johnny's Avatar
FL Johnny
Stage IV
Also check the float height...
JT
Old Jul 26, 2005 | 02:46 AM
John TN's Avatar
John TN
Good advice above, the floats could be stuck as well. Did you go thru the carb?
John TN
Old Jul 26, 2005 | 12:45 PM
Pat's Avatar
Pat
The float was stuck on mine. Simply undid the bottom of the carb (no need to take it off the bike) blew some air in there and everything was fine when I put it back together. Took about 15 minutes.
Pat
Old Jul 29, 2005 | 03:14 AM
JugsReturn's Avatar
JugsReturn
dropped the float bowl to find that there was not a needle in the seat. That fixed everything.
Thanks for the help
Old Jul 29, 2005 | 11:04 AM
HDF Tech's Avatar
HDF Tech
Yep, that will definately do it!
eightysix
Carburetor Related
May 28, 2015 07:30 AM
Kyman671
Apr 7, 2015 08:47 AM
benoit
Jul 8, 2012 03:52 PM
trozenhorse
Jul 21, 2010 12:00 PM
Paulution
Jul 29, 2007 08:10 AM
