How do you do Compression checks?
Old Feb 26, 2012 | 12:53 PM
Fierofly's Avatar
Fierofly
Default How do you do Compression checks?
How to? I'm used to the old car motors were we would ground out the coil wire so you didn't damage anything. Do ya'll disconnect anything or ground out anything to prevent damage on the newer computers? Is there a How To thread? Thanks
Old Feb 26, 2012 | 01:36 PM
roadkingharry's Avatar
roadkingharry
There's a how-to thread here. I tested mine cold and hot to check for any difference, only 2 lbs. I removed my spark plugs, put 'em back in the spark plug wires and then grounded the spark plugs to the engine with copper wire and alligator clips.
Old Feb 26, 2012 | 01:44 PM
soft 02's Avatar
soft 02
Remember if the # is low squirt some light oil in there and if the # comes up then the rings are the culprit. A leak down tester is another great tool for diagnosing compression issues.
Old Feb 26, 2012 | 02:34 PM
djl's Avatar
djl
Pull plugs and ground them; make sure the battery is fully charged; connect the tester, hold throttle wide open and crank the engine through enough cycles, say 5-6, but crank until the needle stops. A weak battery will produce inaccurate results. Plus what the others have said. You can test hot or cold; in my experience there won't be much difference if the top end is tight; a little but not much.
Old Feb 26, 2012 | 04:03 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
As djl describes, but we go 8 complete cranks, with battery charger in place.
Scott
RKRider77
General Topics/Tech Tips
Sep 24, 2017 11:38 AM
br3or
Ironhead
25
Feb 23, 2013 09:35 AM
EvilWayz
Ironhead
13
Sep 7, 2010 05:40 PM
Professor
11
Jun 12, 2010 10:32 AM
BigE410
Feb 19, 2008 11:55 AM
