valve floating
Old Mar 19, 2012 | 08:36 PM
Brick0044's Avatar
Brick0044
Default valve floating
Ok I have the Crane 570 cams installed and love them but, a couple times when winding it up and shifting to the next gear it would fall flat on its face. I think it is called valve floating
. Is there a stronger valve spring that I would need to put in to solve that problem? If so how hard is it to do the job? Thanks in advance.
Old Mar 20, 2012 | 05:33 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
A weak spring, that would cause a un-controlled valve event, would usually result in valve/valve contact, and once that occured, the engine would operate in a very poor fashion.
I would be much more inclined to believe that it is a fuel issue, pipe(s) are pinching the peak delivery, or you are running out of cylinder head flow.
Scott
Old Mar 20, 2012 | 06:13 AM
prodrag1320's Avatar
prodrag1320
right,your going to get one chance at valve float.sounds like the tune is wrong
Old Mar 20, 2012 | 08:11 PM
Brick0044's Avatar
Brick0044
Thanks guys, thats why I asked here because there are alot of smarter people than I here. Will call the tuner and have him check it out. Will let you know how it works out
Old Mar 20, 2012 | 11:07 PM
Fastrider124's Avatar
Fastrider124
It is strongly suggested that you use roller rockers and 175lb base springs on a 570 lift cam. While the valves may not be trully "floating", they can bounce off the valve seat with insufficient spring tension. This won't go on for long before you have cylinder leak down/ valve guide issues.
The other thing that comes to mind is the Rev limiter, stock is about 5700rpm, SE ups that to 6200 for most applications. Could it be possible your bouncing off the limiter with your newfound power?
Just some thoughts to ponder. Fastrider124
Old Mar 21, 2012 | 04:08 AM
Brick0044's Avatar
Brick0044
I dont think it is the rev limiter because if I'm running through the gears and it does act up then I shift it still is flat until I let up and then throttle again. It just cuts right out like you shut off the key.
Old Jun 27, 2022 | 08:45 AM
2FastEddie's Avatar
2FastEddie
6th Gear
Did you ever find out what's wrong with it?
Mine does same thing at times.
Old Jun 27, 2022 | 05:02 PM
handirifle's Avatar
handirifle
The original post was from 2012, so I doubt you will get an answer.
Croop88
Aug 20, 2018 04:54 PM
augiedog
15
Dec 1, 2017 08:03 PM
Eggman1
Jul 10, 2016 12:31 AM
PanheadBill
Panhead
Jul 9, 2012 07:27 PM
Stng72
Sep 6, 2010 09:53 PM
