Cam Spacers
Old Mar 21, 2012 | 08:24 PM
Kaycee's Avatar
Kaycee
Default Cam Spacers
Tryng to get my cam gears lined up evrything seemed fine on the install of cam chest.When I put astraight edge on the gears I am about 10 k out on the front of gears with a .120 spacer so need to go bigger,but when I check the rear part of the gears they seem to be a bit farther out maybe a coupla thous. more than the front .Is this normal???So I thought I would do my SE. adj. push rods how do I set them with dry lifters ?The bike has been sitting for a coupla months so I think the lifters have bled down.I tried to set them per inst. but they never bleed down after a 10-15 min. wait.So I gave up and came in the house before I totally lost it
Old Mar 22, 2012 | 11:03 AM
djl's Avatar
djl
You said "about .010" out on the front sprockets. If you can't get a .010" feeler guage blade under the straight edge; if you can, go to the thicker spacer. No sure I am following your comment on the "rear part of the gears" and a "coupla thous more than the front". I don't think there is anything to worry about but can't really say because I don't understand your comment.
Adjust them dry the same way as wet; they will just bleed down faster. The lifters won't bleed down while just sitting on the bench. What lifters? If OEM lifters, they should bleed down in 10-15 minutes so there must be other problems? What was your adjusment procedure? Was the piston at TDC on the compression stroke? How many turns? etc. Give us more information.
Old Mar 22, 2012 | 06:52 PM
Kaycee's Avatar
Kaycee
Hey thanks for the help I had to get e .150 spacer the biggest 1 they had,allso got the lifter adj. took then allmost 30 min to bleed down .
Old Mar 22, 2012 | 08:41 PM
djl's Avatar
djl
What lifters? 30 minutes to bleed down dry is unusual but, good that you got it done.
Old Mar 22, 2012 | 10:07 PM
Kaycee's Avatar
Kaycee
Stock lifters were re-used
glidein wide
EVO
Mar 5, 2018 10:02 PM
Kaycee
23
Mar 6, 2016 02:31 PM
omgtkk
EVO
Feb 13, 2011 04:36 PM
67xlch
Oct 24, 2007 07:37 PM
radio
Aug 6, 2007 09:16 PM
