2007 Street bob. I'm putting in Andrews 48 cams. I also installed chrome lower rocker boxes. As long as I had it that far apart, I installed cometic 0.30 head gaskets. In an earlier thread, someone had contacted Andrews and found out that the 48 cams have a slightly smaller base circle, so if you installed both the 48's and 0.30 HG's you could still use the stock push rods.
So, I now have the rocker arm/support plate reinstalled and torqued down. According to the service manual, with both lifters on the base circle, the pushrods should "spin freely."
Well, those suckers don't spin. They won't even turn by hand. (I admittedly don't have the strongest hands) They will turn using a tiny set of pliers with some rubber in the jaws.
Is this a problem? Do the lifters just need to compress or something?
I'm FAR from an expert but...Did it sound funny when you turn it over? Like timing funny? I may be WAY OFF BASE but it sounds like the timing may be off if it's backfiring.
I could be way wrong & hate to even suggest it but....Are you sure your cams are lined up correctly? In my thinking, backfiring after doing a cam install points to timing in my simple minded book. I hope I'm wrong & I'm sure others will chime in.
Check for exhaust leaks, they're frequently the source of backfiring. Even a little leak at the muffler to header joint can cause some loud backfires. Make sure everything is buttoned down good.
If your compression is fairly equal on both cylinders, your cam timing is almost certainly correct. If your cam timing was incorrect, you'd have a big variance between the two cylinders. Make a couple of vtune runs and see if it starts to work itself out.
I did a 107 build with tw8 cams this winter, when I first fired up the bike on a map for se257 cams, I was getting all kinds of snorting and bucking, but vtuning worked it out pretty quickly.
These things can be very sensitive to exhaust changes or problems. I got my bike half-tuned with one set of baffles, decided I didn't like the way they sounded, so I switched them out, and it felt like I was starting from scratch on my fuel map.
