SE piston help
Old May 20, 2012 | 01:53 PM
PHA-Q's Avatar
PHA-Q
Default SE piston help
I got a set of pistons from a buddy, no box, only numbers I can see on the pistons are
22122-99. Also STD, and the SE logo.. They are cast, they have a small pop up dome on them,
I'm pretty sure they are the 22661-99a pistons.... But not 100%
Thanks for any info you can help me with...
Mike
Old May 20, 2012 | 02:44 PM
SportsterBob's Avatar
SportsterBob
You may be spot-on...Don't know if this link helps?
http://www.latus-harley-davidson.com...ON-KIT-STD.htm
Old May 20, 2012 | 03:56 PM
PHA-Q's Avatar
PHA-Q
After some heavy research it looks like im right, the 22122-99a is the part # for a single piston. These are the 22661-99a high comp cast pistons...
Prob is they will set my comp to high if I use the .030 HG. Around 10.6... Either have to mill the piston domes or use a .045 stock head gasket!!!!!
The cams I wanna use need 9.3 to 10.2 comp.
Old May 20, 2012 | 05:17 PM
SportsterBob
Even if you use the .045" gaskets you should check the valve/piston dome clearance. The cam kit should come with the specs that state the valve lift at the overlap period.
Dale C
Engine Mechanical Topics
Apr 3, 2019 04:08 PM
twism_23
Nov 16, 2012 03:07 PM
PHA-Q
May 29, 2012 10:17 PM
patriot 02
Apr 23, 2012 07:36 AM
PHA-Q
Dec 22, 2011 07:50 PM
