right cam for high compression?
Old May 28, 2012 | 06:46 PM
jlasoftail's Avatar
jlasoftail
Default right cam for high compression?
So I finally listened to you guys and went and got a compression test done. The guy at the shop laughed and said ok, i believe you now, no wonder you're pinging. My compression, which should be at 190 aprox, was about 220. So, what to do now? I can either put in a new head gasket and lower the compression that way, or I can find a better suited cam. He has no idea why it's up so high, but I have to do something about it now. One of the better builders around here says that he'd through a Red Shift 575 cam in it, which should give me great power, and he's pretty sure it'll help with the ping, but he's not 100% sure. Any suggestions?
Old May 28, 2012 | 06:56 PM
djl's Avatar
djl
Post the build details again, i.e., bore, stroke, chamber volume, head gasket and cams. A head gasket change isn't going to move you from 220 to 190. You need cams with a later intake close.
Old May 28, 2012 | 07:08 PM
jlasoftail's Avatar
jlasoftail
Well I can only tell you this: standard 103 bigbore kit from hd, se255 cams, and stock everything else. the specs for the RS 575 are
I:25/98/41
E:49/105/17
246
246
.575
.575
Any thoughts? I'd rather do a cam swap then a gasket change anyways, but I want to keep my torque fairly low and lose the ping. Right now I have my timing set way back to stay away from the ping, but I'm losing power and can't get rid of it all together.
Old May 28, 2012 | 09:09 PM
2009blackpearle's Avatar
2009blackpearle
Default 255 comp will be higher
I have 255 in my build with se mva heads and 10.5:1 pistons the cold cranking pressure with the throttle plate at idle position pumps out 225 lbs so If i take a reading with the throttle plate open I caN ONLY IMAGINE HOW HIGH IT WOULD BE. I stuck the stock cams in and compression went down to 185 and 240 with throttle plate forced open. I still hAve to figure out what to do either pull the pistons and put flat tops in or change the cams or both. if your compression is high now it will be even higher with 255 they open the valves a few degrees past tdc and stay open all the way down to bdc .
Old May 28, 2012 | 09:22 PM
jlasoftail's Avatar
jlasoftail
I already have the 255's in... that's my problem... and my pistons are flat tops already, so I'm left with the cam change. I'm thinking a se204, or I can get a great deal on a RS575, and I love those cams, but I don't know if the 575 will help or make it worse. Any help would be great because I need the bike ready for a 11 day run starting next thursday. 575 yay or nay?
Old May 28, 2012 | 10:36 PM
MBrown's Avatar
MBrown
The RS 575 will drop your ccp more than the SE204. Looking at the calculator, if your @ 220 now you should be around 205 with the RS575.
Old May 28, 2012 | 10:38 PM
jlasoftail's Avatar
jlasoftail
ok, that's a good start. So I'm thinking the 575 and maybe retard the timing a hair and I should be pretty drivable without a ping and racing fuel?
Old May 28, 2012 | 11:33 PM
DeneFXDWG's Avatar
DeneFXDWG
My recent 96 upgrade build which included 103 flat top Hypereutectic pistons, .030 MLS and the 204 cams doesn't ping at all so far, (summer isn't here yet). The dyno tuner did a great job and used the TTS. I showed 220 front and 205 rear CCP, tested with the throttlebody wide open. Good luck, interested to find out how you make out.
Old May 29, 2012 | 06:52 AM
prodrag1320's Avatar
prodrag1320
check your cam timing or cc your heads (they mayhave been milled),a 103 with 255`s shouldnt be anyware near 220.something aint right
Old May 29, 2012 | 09:05 AM
djl's Avatar
djl
Kirby is right, as one would expect; something is wrong. Your CCR should be under 200psi with a standard BB kit and 255 cams. The gauge is reading wrong or, as Kirby suggests, heads were milled. You need to know what you are working with before you start making any changes. I would check compression again with a different gauge, probably more than one before I accepted 220psi as CCR. Too many guys are running that combination without issues.
