Engine starts and idles like a champ. Once it is given throttle it bogs down, misfires and runs like hell. Started a month ago at high RPMs and has gotten worse and worse until now where it will only idle
So far I have..
put in new plugs, cleaned entire carb and jets, checked the fuel flow from tank to petcock to filter to carb, sealed pipes at exhaust flange
Pushrods? They need to be adjusted on ironheads somewhat regularly.
Ignition? If it has been converted back to points, have you set the gap and checked/lubed the advance mechanism?
Tested the coil at primary and secondary locations.. tested just fine
Tore the whole carb apart again.. no clogged jets etc cleaned everything..
cleaned all hoses etc in the fuel system..
So far I have..
