Performance Tips
Old Aug 4, 2012 | 07:04 AM
SMittFLHTRX's Avatar
SMittFLHTRX
Stage III
Default Performance Tips
I know that ther are alot of threads out there to getting the best performance out of my bike, and I plan on reading them all, I am a new member and I need to get my 30 threads out there before I can post some things on here that I need to sell. Best bang for the buck on my Road glide? I am looking to buying V/H twin slashslip on pipes and Big sucker A/F, how much Gain can I expect to get out of this change, my 2012 Road Glide is a 103ci. If you are interested in what I am trying to sell send me a message through here and I will give you as much detail as I can give you. just dont want to get in trouble for sending a classified in this post. Item that I have were from a 2005 Nightrain. Looking forward to learning new things about my new bike on this site.THANKS for your help
Old Aug 4, 2012 | 09:16 AM
djl's Avatar
djl
Originally Posted by SMittFLHTRX
Best bang for the buck on my Road glide? I am looking to buying V/H twin slashslip on pipes and Big sucker A/F, how much Gain can I expect to get out of this change.
Not the best pipe selection for performance and you didn't mention fuel management. A typical Stage I upgrade accompanied by a good fuel management system like TTS, PCV or SEST and a good dyno tune will net you about 10% increase over stock; a little less on the TQ side and a little more on the HP side; YMMV.
Stage I upgrade with a factory remap of the ECM, i.e, the Stage I "flash" in lieu of a fuel management system and tune won't deliver that much of an increase.
A set of Rush or Cycle Shack slipons and the SE air cleaner upgrade won't cost as much and will deliver the same increase if tuned. You might consider removing the catalytic converter from the OEM head pipe but the benefit of doing so is the subject of debate on this and other forums. Personally, I would not buy a bike that ran a catalytic converter but that's just me.
Old Aug 5, 2012 | 10:25 AM
grbrown's Avatar
grbrown
The way to get the best out of your bike, after modifying it, is to have it set up on a dyno. That isn't cheap, but is well worthwhile in my experience. It is amazing how much better a bike can run. Simply bolting stuff on is only part of the process and as djl indicates the wrong mix of parts may give you very little improvement, but a wise choice can be very well worth the expense.
I suggest you consider just what mods you would like, say during the next few months. If you would like to do more than pipes and air filter, save your money and wait until you can afford to do it all in one go.
More important still, spend time finding a local indy with a good track record on dyno tuning and ask his advice. Visit and talk through what you are after with him. If he supplies, fits and dynos your bike you should get a good package and be confident that it will work well. Take his advice on a tuner and don't try to cut corners.
Old Aug 5, 2012 | 02:47 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Tuned, you will see a nice increase.
Scott
Old Aug 6, 2012 | 02:05 AM
sfmichael's Avatar
sfmichael
Fuelmoto has proven Stage 1 and 2 upgrade packages for late-model bikes and most guys rave about them.
Other sources could be Fullsac and Kuryakyn, among others. Lots of good companies out there. Fuelmoto is a sponsor of this site.
Your gains will be quite different depending on how extensively you modify the bike or to what "Stage". Most vendors have dyno graphs showing how much improvement to expect.
Good luck.
Old Aug 6, 2012 | 10:39 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Almost any air cleaner that does NOT send the hot oily air from the head breather bolts back into the air cleaner will be better than those that do like the big sucker.
Outlaw HiFlow Air Cleaners
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Aug 6, 2012 | 12:04 PM
jcb1975@yahoo.com's Avatar
jcb1975@yahoo.com
Looked at your ad, have a question for you; where is the crankcase/heads vented to if not back to the intake? Could not figure this out from what I rad/seen on your website.
PC Novice
Milwaukee Eight (M8)
32
Jun 2, 2019 08:10 AM
Fletch19
Sep 17, 2013 09:52 PM
RoadKingAl
Jul 4, 2013 01:30 PM
apx07
Jun 30, 2011 09:11 AM
brucemcd
Jan 20, 2011 10:14 AM
