Evo Big Bore Question
Old Aug 11, 2012 | 02:33 PM
Pimp Daddy's Avatar
Pimp Daddy
Default Evo Big Bore Question
I have qa 1994 FXSTC with the stock 80 inch Evo. I am looking at a big bore and found the Revolution Performance 100 inch big bore kit.
http://www.ebay.com/itm/REVOLUTION-P...17%26rk%3D1%26
Price seems decent. I see I need the cases bored, but I was just wondering if this is simple bolt on, or do I need new heads, carb, cam, etc., etc. to make it work?
Old Aug 11, 2012 | 02:46 PM
Stiggy's Avatar
Stiggy
I would talk to Scott @ Hillside here on the forum as to how big you can safely bore a set of Evo cases. Stock is 3.498". Most big bores that I'm familiar with are 3.625, (3 5/8".) These 100" kits claim a piston bore of 3.875"?
Sounds like you'd be losing an awful lot of metal, ( and strength.)
Your heads would probably bolt up, but you'd be defeating the purpose leaving them stock, IMO.
I would think you'd be ahead of the game to consider an 89" stroker kit instead.
Old Aug 11, 2012 | 10:07 PM
lieutenant G's Avatar
lieutenant G
The kit comes with Jugs, no boring of cylinders necessary.
Old Aug 11, 2012 | 11:01 PM
Stiggy's Avatar
Stiggy
I see that.
It's the boring of the cases to accept the new, larger cylinders that I'd be concerned with.
Old Aug 12, 2012 | 11:45 AM
grbrown's Avatar
grbrown
I looked into case boring for a big-bore kit a few years ago, before buying my 107" S&S and concluded the only safe way was to replace the cases with aftermarket ones. I haven't come across anyone on HDF who has used one of those kits.
We have several HDF sponsors who tune engines, including Hillside. I suggest contacting them to discuss what you would like to achieve and what is practical.
Old Aug 12, 2012 | 02:57 PM
lieutenant G
I see that.
Im retarted
Old Aug 13, 2012 | 05:44 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
We've built quite a few 97" Evo's.
3 13/16"(3.8125")bore is where we go.
Combined with even a mild cam, these are formidable powerplants indeed.
Scott
Old Aug 13, 2012 | 12:47 PM
Kingofcubes's Avatar
Kingofcubes
Your crankcases are too weak in our experience for that kind of power. Why not leave it at 80"'s and go with a stage 3 or 4 kit, 90-95 foot pounds of torque with great street manors and not over stress those crankcases.
Old Aug 13, 2012 | 03:20 PM
Pimp Daddy's Avatar
Pimp Daddy
Can I get a stage 3 or 4 kit for $1000?
Old Aug 13, 2012 | 06:26 PM
Hillsidecycle.com
Sponsor
Yes, 90-95 hp, and 90-95 ft/lbs is a walk in the park with an 80" Evo.
Beaucoup' of those in sevice as well, but those 97"ers..............sure are fun.
Scott
