Cams with headwork vs. without?
Old Sep 12, 2012 | 07:56 PM
djl's Avatar
djl
Originally Posted by deez nuts
If you can it would be good to save up until you can do it all at once. When you do just the heads later after your cam and big bore is done you'll be doing the work twice because taking the heads off you gotta pull the cylinders also in order to replace the ring that seals the cylinders to the case.
It is not necessary to pull the cylinders to change out the heads. If you are careful when removing the heads you just need a couple of 1/2" PVC pipe couplings. Use two head bolts at opposite corners and as soon as you remove one head, secure the cylinders to the case with the head bolts and the couplings. This will prevent bumping the cylinders accidentally and breaking the cylinder to case seal at the o-ring. Have done this multiple times without issues.
allthefineprint@gmail.com
Mar 16, 2019 01:20 PM
adm
Engine Mechanical Topics
Feb 7, 2015 01:56 PM
AZRenegade
Mar 17, 2012 09:53 PM
Mike in Oregon
Jan 31, 2011 09:19 PM
Tltrump
Nov 8, 2006 07:51 PM
