Solving Vacuum leaks
Old Aug 8, 2005 | 04:44 PM
msoucy's Avatar
msoucy
Stage II
Default Solving Vacuum leaks
I hear and read alot of people talking about vacuum leaks. Things like "oh could be a simple Vacuum leak" and so on. None of them talk about how to fix the offending leak. I have a 2002 Sportster 1200C I have a leak where the carb meets the manifold. I have had it apart repetedly. I have replaced the seal. I use the carb cleaner trick to spray it in the area and it still indicates a leak. How the hell do I fix it. The carb is seated nicely, the seal in new. I do not know what to do.
Old Aug 8, 2005 | 04:49 PM
HDWRENCH's Avatar
HDWRENCH
Default RE: Solving Vacuum leaks
First off very sledom have I seen a intake boot leak. But manifold seals all the time. You have to be careful with a substance that will burn. It can be sucking it in through the air cleaner in a fume or vapor form and tricking you Try a spray bottle of water and spray it at the junction of the head and manifold that is where they leak. They if leaking swap the seals, and apply a small amount of dishsoap on the seal to help the seal from sticking ans you postion the manifold. The soap will allow you to move the intake up and down with out damage to the seal. Most common cause of the seals leaking is removal of Ait cleaner backing plate as there is no support and the seal become displaced just enough to suck air. Check you vaccum lines as well, the plastic portion is prone to cracking.
Old Aug 8, 2005 | 05:58 PM
HDF Tech's Avatar
HDF Tech
Also take a look here https://www.hdforums.com/m_85102/tm.htm
Old Aug 9, 2005 | 02:32 AM
mikeisglidn's Avatar
mikeisglidn
good advice wrench! just went and checked mine!!
cuda67bnl
Apr 20, 2022 07:32 AM
customsoftail200
Carburetor Related
Apr 15, 2015 08:07 PM
Moondogger
Jul 8, 2012 10:11 AM
dlnp22
Oil Archive (no new posts)
Sep 21, 2009 02:16 PM
tom73
18
May 14, 2007 09:44 PM
