incurable intake leaks?
Old Apr 10, 2011 | 12:06 PM
cuda67bnl's Avatar
cuda67bnl
Default incurable intake leaks?
Been having some issues with my bike. While trying to trouble shoot the problems, I found that my intake seals are leaking slightly. I've already put 2 new sets of intake seals on it, and can't get the damn leaks to stop. The leaks are only noticable if you spray carb cleaner or something similar around the flanges. What the hell is the secret to getting them not to leak? Never had this issue before, and I'm about ready to put some silicone or something similar on them.....
Old Apr 10, 2011 | 03:48 PM
cuda67bnl's Avatar
cuda67bnl
Anyone??
Old Apr 10, 2011 | 05:40 PM
Dalton's Avatar
Dalton
Take the intake flanges and on the side where there is a raised lip, sand the lip down flush with the rest of the flange. This allows a bit more travel when tightening and will most likely seal up any smal leak you may have.
Old Apr 11, 2011 | 09:15 AM
rh8234's Avatar
rh8234
Are you certain you have a leak? Is it possible that the carb cleaner you are spraying is getting into the intake thru the back side of the AC and not thru the intake seals? Just food for thought.
Old Apr 11, 2011 | 10:08 AM
cuda67bnl's Avatar
cuda67bnl
All fixed now. Sanding down the flanges seems to have done the trick.
Old Apr 11, 2011 | 03:20 PM
Dalton's Avatar
Dalton
Sometimes old school tricks fix new school problems. Glad to hear it worked.
Old Apr 14, 2011 | 07:02 AM
kkiley's Avatar
kkiley
Thanks Dalton, I am having the exact same issue and was wondering what the solution was. I posted this in the softail section and knew I shoulda looked here first, lol
Old Apr 15, 2011 | 06:22 AM
DocDyna's Avatar
DocDyna
Default any pictures available
Can someone show a picture of this intake flange, and the point to sand. Or at least provide a more detailed description so we can figure this point out. Thanks
Old Apr 15, 2011 | 06:54 AM
hrchdog's Avatar
hrchdog
Check out page #4 post # 32 on this link for pics of where and what to remove.
https://www.hdforums.com/forum/touri...-progress.html
Old Apr 20, 2022 | 07:32 AM
Newtster's Avatar
Newtster
6th Gear
[QUOTE=Dalton;8172058]Take the intake flanges and on the side where there is a raised lip, sand the lip down flush with the rest of the flange. This allows a bit more travel when tightening and will most likely seal up any smal leak you may have.[/QUOTE
Are you saying sand down the lip where the bolts go thru the flange to the head until its smooth with the rest of the flange?
JesseDyna
Carburetor Related
17
May 2, 2018 10:36 AM
customsoftail200
Carburetor Related
Apr 15, 2015 08:07 PM
95yj
EVO
Sep 5, 2011 09:52 PM
wdheat1
Sep 1, 2010 06:15 PM
msoucy
Aug 9, 2005 02:32 AM
