Intake seals
Old Oct 12, 2009 | 12:35 AM
wdheat1's Avatar
wdheat1
Stage IV
Default Intake seals
has anyone had problems getting new intake seals to seat,,been tryin for the last two days to stop a intake leak,,,put on new seals,,and flanges,,I think the rear seal has seated,,,but the front one hasn't,,,is there a trick to it?
Old Oct 12, 2009 | 06:19 AM
carlgrover's Avatar
carlgrover
It would be helpful if you posted what model bike you have.
For what it's worth, on my ironhead sportster, intake seals are tricky. To check to see if they are installed correctly, after the bike is put back together and is idling, you can either run a water hose over the intake or a propane torch. The bike will die from the water or speed up from the intake, your choice. Either way, if it reacts funny, the intake seals are not installed properly and will have to be reinstalled. It is trial and error. There are other things to check as well, but without knowing what bike you have, it's not worth trying to explain.
Old Oct 12, 2009 | 06:30 AM
cadman311's Avatar
cadman311
We use WD40 instead of water. You can located the right spot of leak. And sometimes the WD40 will help slid the rubber gasket over into the leak.
Old Oct 12, 2009 | 11:25 AM
wdheat1's Avatar
wdheat1
Stage IV
it is an 05 fxsti, have used carb cleaner, to find the leaks,,i know where they are,,, i just cant get them to stop leaking,,used a bit of soapy water on installation,,
Old Oct 12, 2009 | 07:03 PM
wdheat1's Avatar
wdheat1
Stage IV
have tried everything i cant think of,,,,,tried the stock hd seal,,and the blue jims seals,,,,neither work,,,,using cross pattern on torque sequence,,,what am i not doing correctly?,,,,,
Old Oct 13, 2009 | 05:14 PM
wdheat1's Avatar
wdheat1
Stage IV
found the problem,,turns out it wasnt an intake leak,,,the fuel pressure regulator had come apart,it was low fuel pressure,if your fuel pump is making an odd sound when you hit the run switch,,that is what is....
Old Sep 1, 2010 | 06:15 PM
zrider44's Avatar
zrider44
Stage I
I have a few ?'s regaurding your fuel pressure regulator. Did it make the noise all the time or was it hit or miss with it? Did your bike miss at a contant throatle and and at an idle and shut off from time to time? I'm going through the same thing with my bike,its an 05 fxstdi. I have replaced the intake seals 4 times, just took it to the dealer they told me it was the intake seals, i told them about the fuel pump noise, they didnt hear it. I went there today, rode the bike brought it bake and finaly it made the noise where the service manager could hear it.
cuda67bnl
Exhaust System Topics
Apr 20, 2022 07:32 AM
customsoftail200
Carburetor Related
Apr 15, 2015 08:07 PM
Mr.Barnes
EVO
23
Mar 22, 2013 12:52 PM
tom73
18
May 14, 2007 09:44 PM
msoucy
Aug 9, 2005 02:32 AM
