Intake Manifold Leak
Never had this issue before. Anyone know any tricks for getting a good seal?
No, the gasket goes on the manifold and then the carb gets pushed into it. It's really difficult to get it right doing it the other way. Also, I don't have a leak between the carb and the manifold. The leak is between the manifold and both cylinders.
I did have to walk away from mine and come back to it when I put an S&S on it. Mine is a 93 also.
I had a pinging issue that became apparent after installing a new, quieter exhaust. I thought maybe it was timing, so I started searching back through older posts for ones related to timing. Specifically I was looking for the info about which way to turn the timing plate to advance or retard the timing(counter clockwise to retard, btw) and then I came accross this thread.
This thread described the pinging issue exactly the same as I was experiencing, so I fired up the bike on the stand with the choke on and sprayed some chemtool at the intake to head joint and the idle stumbled with both cylinders. It didn't stumble when I hit the carb to manifold joint.
Using this info, I figured I had a manifold leak. I pulled the bags, pulled the seat and unscrewed the rear of the tank to swing it up, then I removed the horn assembly to get at the manifold bolts. I pulled the carb out as one solid unit and pulled the old o-rings out of the manifold rings. They didn't look bad, but were pretty squished. I guess in my haste to put everything back together after replacing the head gaskets, I overlooked the manifold rings.
I cleaned the surfaces, put in the new rubber seals that came with my top end gasket kit, then put everything back together the way described above. I put a stud into the right side front cylinder mount to keep the carb aligned, then lined up the manifold rings and started all 4 screws to finger tight. Next I went 1/2 turn at a time on each screw, moving clockwise until all 4 were tight(front lower, front upper, rear upper, rear lower). I finished attaching the carb, hooked up the fuel line, fired her up with the choke on and tried the chemtool again. This time the idle did not change at all. I guess I fixed the leak! I put her all back together and was going to go for a ride to test it out, and it started downpouring outside! Figures...
I guess I'll wait a bit for it to quit, then see how she rides now. I'm guessing with no leak now and a big leak before, she will probably run a lot better...
i believe it's part #40054-01.... only 20.00.... but everything will be nice and lined up
when i did it, i lightly coated the edges of rubber with dialectric grease so that nothing would fold....and when i tell you 'lightly'...i mean, LIGHTLY
