Rollin free
Old Oct 27, 2012 | 10:58 PM
ROLLIN FREE's Avatar
ROLLIN FREE
Stage III
Default Rollin free
1987 evo , exhaust temp at rear head 200 degrees cooler than front head , normal?????/
Old Oct 28, 2012 | 11:10 AM
95custmz's Avatar
95custmz
What are both temp. readings? Rear head should be warmer.
Old Oct 28, 2012 | 04:38 PM
ROLLIN FREE
Stage III
Front head rite at flange is around 520 rear is around 180 200 range , have checked plugs swapped plugs around , no change getn ready to do a comp check on it , bike seems to run fine ,but rear cyl seems to be cold to warm exhaust at idle
Old Oct 29, 2012 | 08:25 AM
jcb1975@yahoo.com's Avatar
jcb1975@yahoo.com
Compression test for sure. You don't have adjustable valves on that thing, do you? If you do, check adjustment.
Old Oct 29, 2012 | 09:52 AM
ROLLIN FREE
Stage III
Checked comp , 130 on both cyl with carb open , pulled cam cover all marks good , could it just b a weak coil on that cylinder ?
wichris
Engine Mechanical Topics
22
Jun 1, 2017 04:06 AM
Captain Bob
Apr 22, 2014 07:05 PM
sicpup
Jul 1, 2011 10:41 PM
Beaver 550
Shovelhead
Oct 21, 2009 08:09 AM
markcrain
Jul 24, 2007 07:32 PM
