runing prob
Old Feb 2, 2013 | 09:05 PM
shine355's Avatar
shine355
1st Gear
Default runing prob
any one ever have ther bike when i start it some times it only hits on one cylinder and with in 2 seconds the other one kikes in.out a new ultima ignition kit in it and it still the same thing. any help wood be grat full.thanks
Old Feb 2, 2013 | 10:28 PM
BC45's Avatar
BC45
More infor might help get a reply. What year, modle, carb or fuel injection, motor or other upgrades?
Old Feb 3, 2013 | 09:29 AM
shine355's Avatar
shine355
1st Gear
it is a 1997 fxdwg and it has a new mikuni hrs42 carb. new ultima programmable ignition kit in it new accel wires. has 125 comp on both cylinders.has new intack gaskets.
Old Feb 5, 2013 | 04:02 PM
BC45's Avatar
BC45
Since it only happens intermittanly and ony for 2 seconds it will be hard to fined the problem. Since it is carb its not fuel leaking down into 1 cyl and has to clear out extra fuel on start. If it were mine I would get a inductive KV tester that you hold onto the spark plug wire it has a small light in it and when it picks up megnatick field of the voltage in the spark plug wire it flashes. And every time you start it hold it on one of the wires, When it does miss hopefully you will be able to rule out a spark issue and or if you have a spark issue on 1 cyl foe 2 sec.
Old Feb 8, 2013 | 11:17 PM
shine355's Avatar
shine355
1st Gear
Smile
sorry was out of town. bc45 i will give it a try it makes sence.thanks for info and i will let you now. thanks
Old Feb 8, 2013 | 11:37 PM
46u's Avatar
46u
In 92,000 miles my 02 ultra did that twice. Mine is EFI so I do not think it was gas in the cylinder.
hanoverdigger
Nov 5, 2021 08:16 PM
rfranz1952
Aug 17, 2021 03:16 PM
grahamzies
Jul 9, 2015 02:03 PM
petewood70
EVO
19
Jul 1, 2010 06:55 PM
SANDMAN69
May 6, 2007 03:39 AM
