07 96" build fatboy
Old Feb 9, 2007 | 10:17 AM
user 78082023840's Avatar
user 78082023840
Default 07 96" build fatboy
With headwork and proper cam selection along with a D&D fatcat 2-1 exhaust s/e filter,sert or pc111 maybe a thundermax will this motor produce 100 hp and 100 torque and if so which cam choice would be the best for a stump puller? Thank you much Peace and Prayers
Old Feb 9, 2007 | 04:18 PM
HDWRENCH's Avatar
HDWRENCH
Default RE: 07 96" build fatboy
being that you have a stroker crank you can go 103 or stay at 96. WIth a 96 inch and proper head work I would use the S&S 510 gear drive cam kit ans set compression at 9.8 and you will make into the 100+ hp and 100tq with out any issues. We did head work 204 cam 9.6 compression made 98hp 107tq . WIth a cam of better stats you would easyly be in the mid 100 range and tq at 110 maybe more?? Tune would be the thing to get right. I am a DTT fan more so than thunder heart ( zippers item they buy else where) for a controller.
Old Feb 9, 2007 | 07:27 PM
ButtMan1000's Avatar
ButtMan1000
ORIGINAL: HDWRENCH
Just what type of headwork is best suited for this application?
What about the HTTC Ported heads from HD, in relation to modifying your own heads, excluding cost?
Thanks,
machinehed
Jan 6, 2020 06:42 AM
just plain john
Mar 28, 2013 11:56 AM
harris48cars
Dec 25, 2010 05:23 PM
mrdakotaman
Oct 14, 2009 05:29 PM
FLSTF
Apr 12, 2009 03:26 PM
