another 'white smoke' question
Now I'm noticing that some white smoke is coming from the heads, not from the intake ports, or the exhaust ports, but from just all over the heads.. Could someone just reassure me that this may just be some oils and stuff used in the CNC process that's burning off?
I bet you're fine, and if you're not, you've got a great plan my friend.
I just installed my first set of cams on a HD and the different sounds it makes had me putting my ear so close to so many different components I'm lucky I didn't burn myself in the process. At this point I'm convinced the actual valvetrain is quieter than it used to be but you can hear a difference in the sounds coming from a Stage 1 A/C due to different timing and an overall more aggressive cam.
I would equate your experience with your new engine to walking point. Pay attention to everything. You may run yourself ragged and stress yourself out but all that's well will be well and all that's wrong, well, you'll notice it whereas if you just let it ride you might step into something you weren't looking for when you should have been paying better attention.
Good luck and congrats on your first build. (this opinion has been made by someone who has more experience walking point than building motors, FWIW)
