Bike won't start
Old Mar 9, 2013 | 04:24 PM
bentheresd's Avatar
bentheresd
Stage IV
Default Bike won't start
Got a 73 sportster. Just rebuilt the engine. Has spark, but even when I inject it with starting fluid I can't get a rumble, back fire or nothing. Any ideas?
Old Mar 9, 2013 | 04:58 PM
Gerk's Avatar
Gerk
Way too many possibilities. First question is...How skilled are you at engine building? Not a slam just a question.
Old Mar 9, 2013 | 06:12 PM
bentheresd's Avatar
bentheresd
Stage IV
I've rebuilt several jap engines, but first time for harley. All timing marks on cams are correct, oil pump timing marks are correct. Valves are adjusted properly. Points are set at .018. Compression test is 115 front and 110 rear. Spark seems just a little weak but should be enough to fire.
Old Mar 9, 2013 | 10:33 PM
gsxrboy96's Avatar
gsxrboy96
Are you using ether to try and get it to backfire ?
Old Mar 10, 2013 | 10:58 PM
46u's Avatar
46u
So you gap the points a lot more to tuning one then that. Is the gap equal or close on both cam lobs? What sort of shape is the advance unite in? Did you static time it? Is the push rods adjusted properly. You say you rebuilt it what all did you do?
Old Mar 15, 2013 | 10:45 PM
nytryder's Avatar
nytryder
Not trying to be a smart *** but is there fresh gas in the tank? On the other hand if starting fluid doesn't get a reaction fuel probably won't help.
FLHP1034ME
May 4, 2010 01:52 PM
Countrysinger
May 3, 2010 11:22 PM
SportsterSeventy9
Ironhead
Oct 20, 2009 05:37 PM
Neckball
11
Feb 16, 2008 09:11 AM
Born2run
Mar 5, 2006 08:11 PM
