2006 wide glide question
Old Feb 13, 2007 | 03:24 PM
Macs06WG's Avatar
Macs06WG
Default 2006 wide glide question
i am in the middle of installing the SE forged pistons with SE 257 cams. I am doing head work (port, polish, mill and springs) i was wondering if it would help to install the 50mm intake? any help would be nice thanks guys
Old Feb 16, 2007 | 02:30 PM
Macs06WG's Avatar
Macs06WG
Default RE: 2006 wide glide question
has anyone here even tried the bigger TB?
Old Feb 16, 2007 | 05:13 PM
PhilM's Avatar
PhilM
I have gone from the stock 44mm to a 48mm & it does help HP #'s , but I've been told that the larger TB's can reduce velocity and cylinder fill.
I do not think it's beneficial on a 95" build. Mine is a 98" & makes great torque & HP, but I can't help but think that it might have been even better had I not gone that route, even w/the 98". Just my opinion.... I'm sure others will chime in.
Old Feb 16, 2007 | 07:33 PM
bobcowan's Avatar
bobcowan
I think (but could be wrong) that the '06 Dynas came stock with a slightly bigger 48mm TB. Check part numbers to be sure. I wouldn't think a 50mm would make enough of a differance to be worth the expense.
Old Feb 17, 2007 | 07:25 PM
Macs06WG's Avatar
Macs06WG
a stock 06 is 46mm so it would be 4 mm bigger
it cost $400 more, but i already have it apart so putting on would be easy
Old Feb 17, 2007 | 08:59 PM
roadglide65's Avatar
roadglide65
IMO its not worth it not enough HP gain for the money. You say your doing the heads go ahead and clean up the TB and intake with a dremmel and make sure the intake and the head ports don't have a step in them.
Morpheus515
Jun 27, 2015 07:07 AM
Griff012FLHX
Dec 26, 2012 07:44 PM
fullpackage98
Jan 19, 2008 11:37 AM
Towpro
May 3, 2007 06:47 PM
fripple
Dec 21, 2006 10:11 AM
