Poor Drivability Mystery Solved
Old Jun 9, 2013 | 09:29 AM
northeastconfederate's Avatar
Default Poor Drivability Mystery Solved
I have recently solved (or HAD solved) a couple of mysteries. My '02 Road King (injected) was getting abysmal mileage and running rough at low speeds & light throttle. It also had an intermittent miss. The bike has >86,000 miles on it & has never had its fuel filter replaced, so Istarted with that, which improved the rough running but the mileage stayed the same, & the intermittent miss was still... intermittent. At first, I thought it was gone but it reared its ugly head now & again still.
The bike would also occasionally idle lower than normal & didn't seem to "bark" right to life when starting. It would sort of weakly begin to run after several cranks of the starter but once running seemed ok. I thought all of this over quite a bit & decided it seemed like low fuel pressure. For various reasons after talking withthe local dealer's service department I decided it would be more cost effective for me to justthrow parts at it than to wait for an appointment and pay diagnostic time. So I threw a fuel pump and regulator in it.
The result was that my mileage came way back up: I had been getting 30 mpg running 80mph on the freeway solo. I'm currently on a short road trip packing my wife & loaded bags, running 80, & am getting 41 mpg! The bike runs much more smoothly, too. I now believe the pump was on its way out for quite a while, probably in part because I didn't change the filter.
However, the intermittent miss remained & became more regular. So, I stopped at the HD store in St George, UT where we are for the weekend, with only 3 hours until quitting time. I got an experienced, conscientious tech who quickly diagnosed the front injector & suspected a broken wire. He raised the tank & found one of the wires pulled out of the terminal. This was repaired & I was back on the road for only an hour labor!
Old Jun 9, 2013 | 11:34 PM
michaelgmHD's Avatar
michaelgmHD
2nd Gear
Thanks for the info.... Just a few MORE things for me to consider with my 08 Sporty 1200 :-) that has some similar issues...
Old Jun 9, 2013 | 11:43 PM
ynots's Avatar
ynots
Great job diagnosing the nightmares! Thanks for passing on your findings.
MilesOfTexas
2014-2024 Touring Models
23
Jan 2, 2019 12:18 PM
blue06flhri
Sep 9, 2018 11:08 PM
FLHPete
May 8, 2016 10:36 PM
DTCOOPER
Aug 25, 2014 09:05 AM
Scubba2
Jun 29, 2012 09:03 AM
