Re-jet????
Old Feb 27, 2007 | 08:43 PM
Booey424's Avatar
Booey424
Default Re-jet????
I have a 2003 883r.I have vance&hines straightshots and a K&N air filter.I also have a screamin eagle coil,wires and plugs.The carb is stock as well as the rest of the motor.Should I rejet? or do anything else to tune it better.I put all the extras on this winter so I haven't taken it out.Seeings how I live near Cleveland,Ohio and the snow here SUXXXX!!!! I have heard yeh and ney on rejetting.So I would like some more opinions on this subject.if possible.Thanks for any and all help.
Tommy
Old Feb 28, 2007 | 10:29 AM
rh8234's Avatar
rh8234
Default RE: Re-jet????
If you put onfreer flowing intake and pipes, you most likely will need to re-jet. When you get a chance to ride it, if you get a lot of popping on decel and some carb farts while running, you will know your are too lean. Study up on reading the spark plugs in your manual too. That will give you good feedback on whether you are too lean or not.
Old Feb 28, 2007 | 02:27 PM
bobcowan's Avatar
bobcowan
The purpose of the carb jets is to meter the fuel to obtain the "perfect" 14.7:1 air:fuel ratio. Yeah, yeah, I know that you alreadyknow that. But think about what that means for the engine (any engine). The carb is set up to flow a specific amount of fuel to match the specific amount of air as designed by the factory engineers.
If you make changes that improve air flow, you must also make changes to improve the flow of fuel. A simple concept; but so simple it gets forgotten.
To make more power, you need to burn more fuel.
If the changes don't require you to change jets, you wasted your time and money.
Go to the nightrider site, there's an excellent carb tuning guide.
hobo1
Jul 26, 2012 01:29 PM
maryland blackout
Sep 14, 2011 03:22 PM
Frisco73
Sep 28, 2010 10:00 AM
flstfjeff
Oct 11, 2007 01:57 PM
f6noob
Apr 20, 2007 02:32 AM
