2009 FLHTCU Automatic Compression Releases
Old Sep 23, 2013 | 08:01 PM
Uncle Larry's Avatar
Uncle Larry
Default 2009 FLHTCU Automatic Compression Releases
I'm toying with the idea of changing the cylinder heads on my 2009 FLHTCU and going to heads with the HD ACR ( Automatic Compression Releases ) while doing other work to the engine. My question is how "involved" is it to hook up and enable the ACR's. Will they just plug into the existing harness on my bike? Do I have to do modifications to the existing harness? Does the harness on the bike have to be replaced/upgraded. I understand that once they are installed they will have to be "enabled" through the dealer. I would greatly appreciate any advice from someone who already done this. Any help, advice or warnings would be greatly appreciated. Thanks for taking the time to reply.
Old Sep 23, 2013 | 08:35 PM
0ldhippie's Avatar
0ldhippie
You will need to get the ARC Harness and change a couple pins around in the main harness. Then have them turned on. The instructions SUCK! Which makes it a pain but I'm glad I got it done.
Old Sep 23, 2013 | 08:48 PM
tubeman426's Avatar
tubeman426
An easy way is to wire them to your starter, a few guys I know are doing it this way, it works good. No need to buy a harness or activate it in the ecm. When you hit the start button they are on and when you let go they are off, so simple
Old Sep 24, 2013 | 06:36 AM
prodrag1320's Avatar
prodrag1320
that's the way we`ve always done it
Old Sep 24, 2013 | 08:45 AM
Uncle Larry
Thanks for the feedback guys I appreciate the idea ... I would have never thought of wiring through the starter.
Old Sep 24, 2013 | 08:16 PM
HD Bobber's Avatar
HD Bobber
Curious....... Do all 103 models come with ACR's (dyna wide glide & fat bob for instance).
Old Oct 5, 2013 | 11:25 AM
Uncle Larry
I can't answer that for you Bobber ... sorry
Old Oct 6, 2013 | 10:02 PM
stogieluvr60's Avatar
stogieluvr60
All from 2012 on and some from 2011. Good thing too because no releases sucks..........ask me how I know.
chapy6767
Engine Mechanical Topics
Mar 12, 2016 01:49 PM
Uncle Larry
Sep 23, 2013 07:41 PM
jrplane
Jul 7, 2013 11:11 PM
jcoopercam
May 20, 2009 08:54 PM
