02 sensor bung threads flat
Old May 15, 2014 | 08:52 PM
ExtremeBaggers's Avatar
ExtremeBaggers
Default 02 sensor bung threads flat
My 2011 RG is getting Vance&Hines BIG SHOTS off a 2009 and I'm using the ThunderMaxx AutoTune with the 18mm wide band o2 Sensors. Well the pipes are used and upon installing the front sensor I notice the flat threads. So my local wrench Tried to tap it ( I asked to borrow the tap because I like to do everything myself) and needless to say he made it worse. But he did get a row or 2 of threads and got the sensor screwed in. Here's the Delema , I think it's cocked and not seated flush. Is this going to give me a problem? How important is the seal on the sensors? Here's photos of the low and high side due to it not being in 100% strait.
Old May 15, 2014 | 08:54 PM
ExtremeBaggers
Another photo from a different angle
Old May 15, 2014 | 08:55 PM
ExtremeBaggers
Now the high side. The worst seal!!
Old May 17, 2014 | 03:45 PM
target64's Avatar
target64
going to have a leak the sealing washer is not sealing the threads off. u will have to try it, and see if it has a exhaust leak. if it leaks just have to grind off weld and weld in another 18mm bung.
Old May 17, 2014 | 04:24 PM
ExtremeBaggers
100+ miles 2day no leak. Thank god. I did put this stuff that fixes muffler cracks around the washer. It's like a silicone substance.
marknett
Feb 6, 2013 06:20 PM
UT-rckr
Jun 29, 2011 10:54 AM
Dango
Dec 23, 2009 10:29 AM
spritee1
Dec 20, 2009 01:17 PM
Hammer02
Mar 30, 2007 07:39 PM
