I love the look of the Big Radius, but the power chamber is a big plus for the Big Shots. They both look great and sound great. The Big Shots look a little more traditional. That being said, I like 2 into 1 better for performance.
Not always the case. Even a true dual can out perform a 2in1. Here's one that out performed the pro pipe and the fat cat on this build. Pretty impressive for a 98 incher.
Originally Posted by djl
98", HD Street Performance Pro Street heads, CR 595G cams, S&S cam plate/pump, Kury 57mm T/B, SE Heavy Breather and Bassani Pro Street exhaust.
That is pretty impressive. I don't know enough about it. Every tuner, speed shop, and mechanic, that I talked, to said that 2 into 1s are better for performance. I didn't research it I just took their word for it. Something about scavenging. Those guys haven't steered me wrong yet.
There will always be exceptions to any rule, but that doesn't mean it is the norm. The 2-2 exhaust on the sheet does better. With that cam, that headwork, that combination of parts. Would it have the same outcome if it was displacing 113 cubic inch with same parts? Or with just a cam swap? How would the 2-1 perform if it had a 2 inch or a 2.25 collector on a 98 build. What insert was in the fat cat? At one time there was 3 different options.
Dyno operators can only report what they see. We aren't trying to lead anyone astray. If 2-2's would constantly show better results over a 2-1. Why would we hide that? Then ask these dyno guys and performance engine builders what pipes they have their own bikes. I bet they are running what they see is making best performance for the combination they are riding.
That may be but to say good power can only be made with 2in1s is misleading too. Some real nice numbers coming from some cross under X pipes 212s too. The Khromewerks comes to mind.
Unfortunately choices are limited for Softails for those of us that can't stand the looks and sound of 2in1s.
I talked to dlj and I'm quite confident those pro streets will perform quite well on my 107 build. Going with turnouts.
Max has a set of custom made duals with glasspacks that do real well too. Extremely flat torque curve across the entire rpm range. The key is stepped headpipes in both cases.
Just tell your tuner what horse power you want and he can tune the dyno to get it.
I'm partial to 2-1(supertrapp), quiet when you want it to be, but you do you.
That is the one 2in1 I absolutely hate the most. The sound is horrid. Like a sewing machine on steroids. Guys that want quiet and performance seem to like it but that combo just doesn't work for me.
Of all of them I've heard in person I'd say the Thunderheader sounds best and performs well. RB Racing's LSR maybe but haven't heard it in person.
The pro pipe is hollow and has a drone at Hwy speed.
Nothing sounds better than true duals but most suffer low end loss due of lack if scavenging. My Rush 212 has a great deep sound and performs well but gives up a little top end hp to a good 2in1 but worth a few hp to me. But the pro streets are a real rare exception in a true dual that performs great across the entire rpm range due mostly to the stepped headpipes and is going on my new build. Khromewerks hp p!us is another great sounding slip on 212 that performs well. Their cross under X pipe performs great but doesn't work on Softails. There's a few other X pipe 212s hat perform great too. Softails just can't use a cross under exhaust. Too low.
There are a few good options for those of us that don't care for a 2in1. But beware, not all 2in1s are worth a crap either. In fact a lot of them suck and have major reversion issues down low.
I try and not talk in absolutes. Learned not to with things I have seen. But the reason a 2-1 works. Is the same concept of 2-1-2's. Same concept has headers on cars or H or X pipes. It's all about tying cylinders together or banks of cylinders together, slugs of air, scavenging, and equalizing pressure.
I also think cam design has a huge influence on how well a particular exhaust works. Seems cams with little or no overlap aren't as pipe selective sensitive as one with overlap or exhaust bias lopes.
Disc pipes aren't magic. They just give a means to tune the exhaust. Just as bending baffle in a thunder header. As a tuner. I like the option. I have learned a bunch playing with discs with different cam profiles, and different cubic inch. Pushed me into more testing. Pushed me into more test equipment. Which has helped my general understanding on exhaust and cams. BUT all of that doesn't help how a disc pipe sounds or looks.
I think in the case of the pro streets here its the stepped head pipes keeping the velocity going and a high compression build making up for the !oss of scavenging and doing a good job of maintaining cylinder fill at a decent rate. That's my theory and the reason for my pushing compression so high.
I know you're not implying that djl's dyno numbers above aren't legitimate numbers or that it involved some dyno trickery.
I would suggest going to Texas and having this conversation with Nick. He will be the 6'8", 280lbs guy standing by his dyno. One of the nicest guys I have met, but I haven't questioned his integrity on a public forum without even knowing anything about the man.
