Anybody Here Done The Conversion?
Old Feb 13, 2008 | 08:34 PM
  #51
Neckball's Avatar
Neckball
Default RE: Anybody Here Done The Conversion?
here is the list of parts and prices when I ordered the conversion, I got them from Zanottis, the 20 percent off really pays off when you do something big like this. here is the list
Item
Quantity
Price
26037-06
$119.60
oil pump
duke76, I just purchased the same list of parts from Zanotti's and somehow I got the oil pump for $93.42. I have no idea why, I just placed the order online and here it is.
I have a question, can you use the same bolts to attach the oil pump from the old cam plate to the new cam plate? I can't tell from the parts breakdown I have.
Old Feb 13, 2008 | 08:59 PM
  #52
duke76's Avatar
duke76
ORIGINAL: Neckball
Item
Quantity
Price
26037-06
$119.60
oil pump
I just looked up the oil pump on Zanottis parts lookup page, looks like they must have dropped the price to 93, surprising for HD parts to get cheaper, I have heard that HD is putting together a kit to retrofit the older bikes to the new hydra tensioners maybe that explains it, yes you can use the same bolts I didnt know for sure so I just ordered them only 5 bucks. HTH Todd
Old Feb 13, 2008 | 09:20 PM
  #53
ajayrk's Avatar
ajayrk
I did the roller chain conversion about two weeks ago and I reused the cam plate and oil pump bolts.
PS I live in the state below NC.
Old Feb 14, 2008 | 10:06 AM
  #54
Neckball's Avatar
Neckball
Will the "Baisley" oil pump spring available from Latus H-D fit in the late model cam plate? Is it an improvement with the new oil pump or is it needed?
I asked this same question a while back on HTT and the concensus was that with the new hi volume oil pump you are using in the conversion that it is not needed but i supposed you could still put it in if you wanted but not necessary Todd
FWIW, here's what is on the instructions from Latus for the Baisley spring-
"Most hydraulic chain tensioners will see a similar benefit in their ability to maintain pressure on the chains to reduce unloading on decel and cam nose over".
With that said, I think I'll just go with the late model oil pump and stock spring. With a stock 88" engine with Andrews 26N cams I think I'll be okay.
Old Feb 14, 2008 | 01:32 PM
  #55
Neckball's Avatar
Neckball
okay, one more thing I need help with. Can anyone tell me the torque spec for the bolts that hold the hydraulic tensioner to the cam plate?
Old Feb 14, 2008 | 10:52 PM
  #56
duke76's Avatar
duke76
If they are 1/4 x 20 like I think they are if my memory serves me correctly they are torqued to 90-120 inch pounds, I put a drop of blue loctite on them and torqued them to 100 inch pounds Todd
Old Feb 15, 2008 | 08:52 AM
  #57
ajayrk's Avatar
ajayrk
Neckball
See my answer @ HTT
TwinCam : Cam Sprocket Spacing
Sauraus
Jan 10, 2025 04:23 AM
WillPwr
Oct 8, 2013 03:59 PM
Mikey 1450
Dec 23, 2010 08:05 AM
RickyB
May 16, 2010 10:15 PM
NCDEUCE
Mar 30, 2008 06:05 PM
