32E generator problems > 36 VLD
Old Apr 23, 2022 | 03:12 AM
Harley VLD's Avatar
Harley VLD
Stage III
Default 32E generator problems > 36 VLD
hi everyone,
2 years ago i rebuild my 32E generator and convert it to 12 volts with the Samwel kit. (new 12v coils, new 12v armature and the V tronic regulator)
After a year there was a little short in the circuit ( i removed the rear wheel for inspection and a wire gets crushes between the fender... stupid..) so the generator and regulator burning out.
No smoke or something, on i ride the bike stops and will never start, battery empty and no charging.
Replaced all the parts , new armature, new coils, new regulator, cost me a lot of money.
To prevent this happening again i placed some fuses in the system, 1 fuse at the + at the battery (30a) and some fuses in the wiring to the lights. I want the bike much as original looking but i can live with some small fuses under the dash and in the battery box.
So far so good, last week the same problem again ! no charging.
Take the generator apart and aigain the armature burnt up.
Reason ? i dont know, all fuses are ok.
how can this happen ?
I can order new parts again but cost me a lot of money and it looks like its not a durable system.
What is the most durable option to convert a 32E to 12 volts and will run trouble free ?
Old Apr 23, 2022 | 06:07 AM
hellonewman's Avatar
hellonewman
When the charging system was new did you check the output and make sure its not over-charging? Also did you test the battery to make sure it doesn't have a bad cell which will make the generator work harder?
Old Apr 23, 2022 | 06:56 AM
johnjzjz's Avatar
johnjzjz
Most wont test the early generator as the gear is pinned on and they use a belt for checking gens and alternators - it rips the belt up
in my shop we made a harley pulley from a gear machines down and pressed in a bored out 2 1/2 inch pulley to match the two
you must check the out load in amps - originally you had a 3rd Brush for amp rate we set. Them as low as possible as most only day ride the machine
electronic regulators need to be low out put as well - you will need help in making that happen
RogueGunny
Electrical/Lighting/Alarm
17
Mar 16, 2022 10:04 PM
indieradier75
Aug 22, 2020 09:26 PM
xknucksx
Jul 10, 2017 10:53 PM
!11B_FXDWDG
EVO
43
Dec 10, 2015 01:36 PM
hdbeggs
May 29, 2013 06:36 PM
