Keep going through batteries
Old Jul 7, 2017 | 10:14 PM
xknucksx's Avatar
xknucksx
Default Keep going through batteries
I have an 06 street bob with about 20k on it (I will note that I still have the original charging system but checks out good), and within the last month I've been through 3 batteries (3 month warranty luckily) I know theres a deeper rooted problem that I can't diagnose here.
Im fairly hard on the bike and the day the first battery went was after a few wheelies and spirited runs. Ill be riding and the bike will randomly lose all power for a second or two then comes back on. The last battery I had in lasted 3 weeks without issue until one day the cutting off and on started while out on a ride, next day not enough juice to kick on had the battery load tested and it was spent.
I have tested the whole charging system 3 times and I'm not throwing any codes, everything comes back in spec. No overcharging, no losing power, and I've been over every wire looking for pinches or shorts as well as loose + or grounds and have come back with nothing.
Im now on my fourth battery and it fired right up and as usual seems good to go but I'm not going to keep roasting batteries, so I'm looking for any outside ideas or things to check before I take it to my indy and spend money on something I can most likely fix.
Old Jul 7, 2017 | 11:40 PM
archergodwin's Avatar
archergodwin
Only a few other components to change in your charging system.. stator, voltage regulator.. and pre 07 were known for having rotten rotors.
Might be worth trying to see how much current your starter is pulling too.
3 batteries? I'd have changed out voltage regulator at least by now... have you checked the output of your alternator? .. jiggled wires?.. loose grounds?
Old Jul 8, 2017 | 01:04 AM
xknucksx's Avatar
xknucksx
Yes Ive checked, had the multimeter out three separate times to see if anything was out of spec and everything falls within spec. Ive jiggled about every damn wire possible and nothing. Im not going to jump to throwing new parts on without more of an idea as all signs point to a working voltage reg at the moment.
Old Jul 8, 2017 | 02:24 AM
bigbadpoppa's Avatar
bigbadpoppa
Stator...
Old Jul 8, 2017 | 10:21 AM
MRFREEZE57's Avatar
MRFREEZE57
what is actually happening?
Is the battery just going dead or is it being damaged by the charging system?
Old Jul 8, 2017 | 11:07 AM
xknucksx's Avatar
xknucksx
My guess is its being damaged by the charging system but I cannot figure out what, I've done every test in the manual for the stator, rotor, and voltage regulator and all come back exactly in spec.
Old Jul 8, 2017 | 11:27 AM
Ghost_13's Avatar
Ghost_13
Yup
Likely one..., or more of those - is breaking down under load / heat / riding conditions
But showing good / working under test conditions
Ghost
Old Jul 8, 2017 | 01:02 PM
xknucksx's Avatar
xknucksx
That makes complete sense, its for sure once it's being out and ridden. It always starts with the bike momentarily losing all power and coming right back on. Would it make more sense being the stator or the voltage regulator? Changing it all is obviously the best bet but if I can get away with just swapping out a voltage regulator and finishing the season I'd be happy and update stator/rotor come winter.
Old Jul 8, 2017 | 01:13 PM
archergodwin
I'd bet the stator, but you need to know.. once one component goes weak, it stresses the crap out of all the others. I had a stator go, and just went ahead and replaced regulator and battery.
Old Jul 8, 2017 | 02:06 PM
Ghost_13's Avatar
Ghost_13
Before digging in - do one additional test
Fully charge the battery
Ride it for 3 or 4 hrs
Park it..., let it cool down just a tad (15 / 20 min) - then immediately hook the charger back up.., and see how long it takes to fully charge
This eliminates parasitic draw as a possibility (for the time being)
And
It'll tell you if the bike is actually keeping the battery charged.., while running
Shouldn't take long at all..., if at all - to charge the battery back to full after the test ride
If it does - then the bike.., while running - is drawing off the battery..., and not charging it
If it doesn't take long to charge - then let it sit for a couple of days - and see if the battery is drawn down - (parasitic draw is killing the battery)
Once isolated - we can go from there
Otherwise it going to be a shotgun crap shoot figuring out the culprit
Ghost
