Keep going through batteries
Old Jul 8, 2017 | 02:55 PM
xknucksx's Avatar
xknucksx
That's the thing the battery never loses charge thru it just fries a cell I'm guessing, will still read 12.9v even after the cell is fried and then when I go to start it it will drop to 6v and cut off then my starter relay clicks away. They always load test them and comes back not useable. With the fresh battery in there I re ran all tests and it's not only holding charge but charging perfectly at 14.3-14.7 while revving and around 13.8 at idle. I haven't taken it out for a ride with this new battery as I'm tired of going back and exchanging them. The other hand is i might ride for a week without a single symptom or it may act up 10 miles into the ride, it's so sparatic.
Old Jul 8, 2017 | 03:46 PM
PWMORRIS's Avatar
PWMORRIS
Something is obviously wrong-
You say everything checks out, but thats impossible. You are missing something.
Check everything again.
This started after wheelies and beating on the bike pretty bad?
This, to me, is a clue.
Alternator wires-check it. In your garage, fine, could be loose under load and vibration.
Check all connections at Coil.
Is the battery isolation rubber still around/under the battery? Did the cables shift or ground loose?
After battery is fried, did any of them look "swollen" or did the case bow out?
Is there a wire that could be getting pinched under the seat after or during hard riding?
RPM's go up when throttle is twisted so alternator is good in garage but under load/stress?
Does Stator wire or plug look like it has moved?
Have you pulled the primary and inspected the stator, or disconnected it and ran a voltage test?
Does bike cut out under load when accelerating?
Any misfires? Bike running normal?
Check plug wires, in and out, and pull plugs. Make sure you are burning clean...
Stators can grenade under hard load-
Here is one of mine after drag racing abuse:
Old Jul 9, 2017 | 12:42 PM
Ghost_13's Avatar
Ghost_13
This
I'm guessing,
This right here says it not the charging system..., but could potentially be the starter shorting out
What the hell
Stop guessing
Approach trouble shooting this crap systematically
And take copious notes over what you're doing / testing - and the results
Otherwise - we're in a circle jerk- which will only get progressively expensive and frustrating for you
Ghost
Old Jul 9, 2017 | 01:16 PM
CaptainAwesome's Avatar
CaptainAwesome
Check your ground.
It's obvious, it's simple, but I've seen it be the problem more than once on an electrical gremlin that couldn't be figured out, including my brother's Harley. Take it off, clean it, sand the contact area, bolt it down proper.
Also check your battery cables while you're at it, sometimes the copper on the inside gets wet and corrodes and then it doesn't work right (could work fine one minute, get slightly bumped and no longer work right if corroded)
I've had a stator go out on a non-Harley bike. Drove to a gas station, wouldn't start up when I went to leave. Couldn't roll start it. Put in a new battery, made it 20 miles before it was dead on the highway. Don't recall any signs that it was going out other than a supercharger like sound in the last 5 miles before it did, didn't notice any trouble starting the bike before this.
There where ways to eliminate where the problem was coming from when I fixed that. Been a while since I did it but off hand, checking the battery even if new, checking the battery while running, checking the R/R when off and running as well as disconnecting a few things to the R/R and checking the read out. Wasn't just volt checking, the Ohm reading off the R/R is where I found it was my stator.
I'm far from an expert on it, just things I've seen it be in the past that might help.
Old Jul 9, 2017 | 01:27 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Just curious where you getting your batteries? Do charge them prior to installation. I might be wrong but I thought an EFI bike voltage at idle is 14.2v min, might be wrong. The battery tender I have is temp. controlled, could take longer on hot days to charge.
Old Jul 9, 2017 | 02:01 PM
skid_pimp's Avatar
skid_pimp
I agree completely, you're going to have to isolate and trouble shoot one thorough step at a time. But would like to add. I've had a voltage regulator crap out on the high side, when hot, and act normally when cool. And another let AC thru when hot, and act normally when cool, neither of which the battery/bike appreciated.
Old Jul 9, 2017 | 10:54 PM
MRFREEZE57's Avatar
MRFREEZE57
I would guess the regulator. had a stater fail on my 81 suzuki GS1000 back in the early 80's, is a very similar charging system, when the stator failed battery would just run down. not sure on the harley but the suzuki specs were 75 to 90VAC direct from the stator . I can not see how a stator would cause battery overcharging but I guess there is always some situations that are hard to detect.
Old Jul 9, 2017 | 11:02 PM
MRFREEZE57's Avatar
MRFREEZE57
if it reads 12.9v, you do not have a fried cell as the cells are connected in series and in a series circuit, any break of connection will result on 0 vdc.
have you tried recharging the battery to see if it will start the bike after charging? that will aT LEAST TELL YOU IF THE BATTERY IS BAD OR JUST NOT CHARGING BY THE BIKES ELECTRICAL SYSTEM.
Old Jul 9, 2017 | 11:13 PM
bad tappets's Avatar
bad tappets
If you are loosing all power, it's probably a bad connection somewhere. As Capt Awesome said, check your cables for corrosion. Check ground strap. Are you buying super cheap batteries? They could be junk.
Old Jul 10, 2017 | 04:52 AM
vonh12's Avatar
vonh12
If the battery is fried I'm voting regulator allowing the overcharge. A fried stator won't charge and running the bike will just run the battery down not wreck it.
