wires
Old Jan 10, 2008 | 10:41 AM
stevodigitalfly's Avatar
stevodigitalfly
Default wires
I need your expert knowledge
can you tell on my 47 generator is pos or neg on left or right ? you can see one is longer at the post
I am overcharging my battery and think when last we worked to find a different problem we may have them wrong
and if I switch then to find out, what will happen ? anything bad or is it ok to try?
[IMG]local://upfiles/45742/34E83E232D54461DB819C2382AB63A4D.jpg[/IMG]
[IMG]local://upfiles/45742/CD50BA262BDE4979AC27D692957CB1D4.jpg[/im
Old Jan 10, 2008 | 11:09 AM
panz4ever's Avatar
panz4ever
Default RE: wires
If you have the standard 32E for your bike there should be a plate that says 'switch' and 'relay'. relay terminal is your positive side.
Just got looking at a couple of pics in the service manual....they show an end section view and from the pics the tall terminal goes to the relay terminal post.
Per manual...on 3 brush generators the standard charging rate is 4 amps with standard operating equipment (tail lamp, speedo lamp and headlight lighted). The regulating third brush is adjusted by loosening the 3 screws under the end of the genrator cover.
A separate current and voltage regulator attached means you have a two brush generator. If the battery is overcharging the manual suggests the problem may be that the regulator is failing to reduce output as it should due to a faulty regulator or generator.
cyclepath37
EVO
Jun 27, 2019 10:24 AM
Nate.Evans
Electrical/Lighting/Alarm
Jun 24, 2018 07:04 PM
0maha
EVO
16
May 10, 2018 07:04 PM
Markeje
May 12, 2016 03:08 AM
Wampuscat
May 22, 2008 08:45 PM
