high"er" compression flathead heads.
Old Dec 24, 2011 | 02:53 PM
hdjunior's Avatar
hdjunior
Default high"er" compression flathead heads.
what would be the market behind some higher compression flathead heads? i am getting into metal working again and im getting supplies together to make a gas forge and a foundry with a crucible to pour the molten metal into molds. i was having a spark of genius a few days ago, get a set of heads off a flathead and make a mold with them and custom cut some type of larger combustion chamber with a possible different design to make the gas and exhaust flow much better. my goal would be to have the compression ratio atleast 1-2.5 more than the stock head off whatever head id use. if i did this what would the interest be in them? i would obviously test them out myself first to make sure they would be ok for sale along with making sure the type of metal id use wouldnt throw off high heat warp and any other issues id run into. if anyone has any feed back on this id really like to hear it.
Old Dec 24, 2011 | 03:38 PM
j1mmy's Avatar
j1mmy
your going to get that bike up to 23hp.. there is always a market for performance parts.. even on an engine that has no idea what performance is..
Old Sep 21, 2012 | 09:39 PM
flatheadbob's Avatar
flatheadbob
Stage III
you know some people are ignorant to the Flathead ...but your thoughts are good ..Flatheads have an over heating problem so by increasing the compression ratio you'll add more heat .....over come the heat FIRST....come up with a cheaper ceramic coating for the exhaust port and valve then you can go to the head...the latest is to ceramic coat the chamber and exh port...more air ....big air pump..remember...later
jcanrun
Nov 1, 2012 05:22 AM
07 dyna man
Apr 30, 2011 04:11 PM
Pittsburghglide2010
Jan 16, 2011 05:10 PM
rmd
Exhaust System Topics
13
Jul 8, 2010 07:49 AM
1931jamesw
Jan 26, 2010 06:54 AM
