Quote feature not reliable
Old Dec 4, 2014 | 10:40 AM
1004ron's Avatar
1004ron
Default Quote feature not reliable
Occasionally the quote function doesn't work - if you hot "quote" is brings up a blank message sheet without the message that you intended quoting.
Old Dec 4, 2014 | 11:00 AM
RANGER73's Avatar
RANGER73
Must be your end.
Old Dec 4, 2014 | 02:48 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by RANGER73
Must be your end.
What he says...
Old Dec 5, 2014 | 12:43 AM
cficole's Avatar
cficole
I have the same problem occasionally, and I've also seen others mention it. It'll happen in some threads, and not in other threads, at the same time of day. The problem threads retain the problem, even a day later, after being refreshed.
Old Dec 5, 2014 | 10:33 AM
hvacgaspiping's Avatar
hvacgaspiping
, `Happened to me just a few minutes ago on another thread.
Old Dec 5, 2014 | 11:08 AM
FXD2003Rider
Once you notice it, please post the thread link in here so we can have a look and try to solve this issue...
Old Dec 5, 2014 | 12:17 PM
Imold's Avatar
Imold
Happened to me a couple times. I quoted another thread that worked from that poster (was easily available both times) and cut and pasted the post I wanted in that one, replacing the text not needed. Just takes a little more time, and hopefully this problem will get resolved before it gets more widespread.
Old Dec 31, 2014 | 06:59 PM
1004ron's Avatar
1004ron
Here's another occurrence - you'll see that I needed to manually quote.
https://www.hdforums.com/forum/gener...l#post13548274
Old Jan 1, 2015 | 04:41 AM
FXD2003Rider
I tried as well and for me the "reply with quote" button (next to the "edit button") works as it should.
Old Jan 1, 2015 | 09:41 AM
1004ron's Avatar
1004ron
After reading your response I gave it another try - the post above mine which brings up a blank text block when hitting the quote button still does just that, but if I use the quote button on my own post or the post above the one I wanted to quote, the quoted text and link to the post appear as normal.
It is quite possible that it is something on my side, but how do we track it down.
