Link is not working
Old Jan 6, 2022 | 11:24 AM
soldierbot's Avatar
soldierbot
Works fine with Chrome and Opera, not working with Microsoft Edge
Old Jan 6, 2022 | 01:26 PM
LQQK_OUT's Avatar
LQQK_OUT
Exactly.
I'm guessing it's some sort of issue with the redirect VaginaLink code.
Old Jan 8, 2022 | 02:41 AM
cficole's Avatar
cficole
Works fine with Firefox 95.0.2 here.
Old Jan 9, 2022 | 11:10 AM
LQQK_OUT's Avatar
LQQK_OUT
The link actually works fine in Microsoft Edge. The problem is the link doesn't work with Microsoft Edge when the link is embedded in the HDForums post.
When I click on the link in the below site (click on RESOURCES tab), it works fine.
https://www.jpcycles.com/product/7278/j-p-cycles-shock-absorbers
Hence, my first impression is that the issue lies in the HDForums code. Is that an incorrect assumption?
Old Jan 9, 2022 | 10:53 PM
cficole's Avatar
cficole
I don't do html, xml, etc., so I can't guess about that. I wonder if Edge has a setting that affects a pdf link in a post. And when you said it doesn't display "properly", what does it do?
Old Jan 10, 2022 | 09:14 PM
LQQK_OUT's Avatar
LQQK_OUT
@cficole The website displays the following message:
The link you clicked on is malformed. Contact the editor of the originating page.
This is the link displayed in the web browser:
"https://j-and-p-cycles.pxf.io/c/29332/1070785/11935?sharedid=1256825&subId1=156074.11935.0FOF147 35975477574226&u=https%3a%2f%2fimg.jpcycles.com%2f staticwebfiles%2finstructions%2fpdf%2f7000240.pdf"
HDforums.com rewrites the link.
Old Jan 10, 2022 | 11:08 PM
cficole's Avatar
cficole
When I copy that (without quotes) into a new tab and try to go there, I get the same message.
In Firefox, when I move the cursor to the link in the first post of this thread and "inspect element", it shows: https://img.jpcycles.com/staticwebfiles /instructions/pdf/7000240.pdf
(I added a space in the middle here so it would show all the letters)
Can Edge retrieve the pdf if you right-click on the link, and save or download?
Old Jan 11, 2022 | 06:45 PM
LQQK_OUT's Avatar
LQQK_OUT
No. When I try to right-click to save, I get a "monetize.htm" link. HDforums re-writes the links using rediect.viglink.com.
If I "Inspect" the link via the browser, it works fine.
As I mentioned previously, Edge browser works fine when I use the JP Cycles webpage and click on this link.
See post #14
Old Jan 11, 2022 | 09:37 PM
cficole's Avatar
cficole
See post #14
Sounds like Edge is the odd man out; it doesn't work and play well with forum links. I got nothing. Good luck.
Old Jan 12, 2022 | 01:05 PM
LQQK_OUT's Avatar
LQQK_OUT
Thanks. But I think the issue is that Edge doesn't play well with websites that use redirect.viglink.com to track referral/ad links.
Blackbird
Forum Issues
Jan 22, 2008 11:25 PM
