Click on "User CP", then click on "Edit Options", then scroll to "Date & Time Options", then make sure your choice of time zone is correct and you are using the Automatic DST settings and also that your start of the week day is correct as well.
Also you may need to make sure you use your zip in your profile because some systems use that also to correctly locate you in the correct time zone....
Thanks for taking care of this one for me. Don't worry about your zip though. Just change your time zone in your User CP and you'll be fine.
