Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Rear Wheel Bearing Replacement
Old Oct 13, 2014 | 12:15 PM
Ghostrder33's Avatar
Ghostrder33
Stage II
Default Rear Wheel Bearing Replacement
I have a 2010 CVO Convertible with 31,000 miles and the rear wheel bearings need replacement already. Kinda sucks because my 96 Heritage has 130,000 miles and I've only changed the wheel bearings once.
Does anyone have any words of wisdom. I'm not even sure what size the nut is because I don't have a wrench to fit it in my toolbox.
I'm looking for a replacement bearing because if the OEM bearings only last 30,000 miles I don't want to put them back in.
Old Oct 13, 2014 | 05:13 PM
Ghostrder33
Stage II
I found after market bearings on bikebandit.com for 1/3 the price of OEM, just hope they are the correct ones when the get here.
I also bought a 36MM socket for the axle nut.
Does anyone know the torque for the nut when I reinstall it?
Old Oct 15, 2014 | 12:21 PM
grbrown's Avatar
grbrown
Get yourself the factory service manual, which will tell all you need. The bearings have to be installed in a certain way, I understand. No I don't have one that covers your bike!
Old Oct 15, 2014 | 02:43 PM
Krutch's Avatar
Krutch
From: somewhere in "The Peoples' Republic of Illinois
Do not hammer the new bearings in! They must be pushed in using the outer race only. And pulled from the other side of the wheel. If any pressure is on the inner race, you chance lowering the life of the bearing.
The installer need to be relieved to make contact only on the outer race rim.
Either get the proper tool, rent one, or take it into a qualified shop.
I made my own tool. But then, I have a machine shop.
plongson
2014-2024 Touring Models
38
Oct 31, 2018 11:53 AM
JakeUSAF
Oct 9, 2017 11:03 AM
0734
Nov 4, 2014 03:12 PM
falconbrother
EVO
Apr 17, 2014 09:13 AM
brazos95
Mar 27, 2007 06:23 PM
