Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
2003 RK rear brake issue
Old Sep 19, 2015 | 12:07 PM
awilcodm's Avatar
awilcodm
6th Gear
Default 2003 RK rear brake issue
While riding the Dragon a couple weeks ago I lost my rear brakes. Pedal went right to the floor. No leaks or fluid anywhere. Got back on the road and made way to the resort. By the time we got to the resort the pedal was back and brakes working as the should. Have ever since. I was not using the rear brake too much prior to the problem. The master cylinder was rebuilt about 2 months ago by previous owner. Any idea's what happened?
Old Sep 20, 2015 | 06:22 AM
M&P340's Avatar
M&P340
Lose any fluid from either master or wheel cyl? If not & brakes are back, sounds like O-ring(s) on push rod temporarily deformed from cartridge cyl walls, allowing plunger to simply bottom in cartridge body without pressurizing. Did PO say the cartridge body was good at rebuild? Shoulda been checked, including O-rings on outside of cartridge body. Aftermarket rear master rebuild kits typically only include a new plunger & associated parts like O-ring, and nothing for the cartridge body which is typically not removed to check the rings on it or bore it is in. The H-D kit, however, includes plunger, O-rings, spring, AND a new cartridge body for not much more than a limited aftermarket rebuild kit.
Maybe was a temporary ring deformation on either plunger or cartridge body, & won't happen again (unlikely). But if does, I'd be looking at a proper/complete cyl rebuild using the H-D kit if twas mine. Good luck!
Old Sep 20, 2015 | 12:20 PM
awilcodm's Avatar
awilcodm
6th Gear
Thanks for the info. Sounds like I will buy the h-d kit for my own piece of mind.
Old Sep 21, 2015 | 04:52 PM
awilcodm's Avatar
awilcodm
6th Gear
One more question. Are the master cylinders different between Police bike and regular Road King? I have the FLHP.
Old Sep 21, 2015 | 11:52 PM
fairfax1000's Avatar
fairfax1000
Default Rebuilt master cylinder
Not a fan of the rebuild unless I do it myself. It requires an ultra clean environment and absolutely good as new bore. Sounds like you have an issue that will haunt you at the worst possible time. Replace it if you can't rebuild it properly. When was the last time you flushed the fluid???
Old Sep 21, 2015 | 11:54 PM
fairfax1000
Default Master cyl
Same part number
Old Sep 22, 2015 | 05:28 PM
awilcodm's Avatar
awilcodm
6th Gear
The reason I asked if they were the same master cylinder is JP cycles said the kit the have will fit a FLHR but not an FLHP. Didn't make sense to me. Same thing with the big bore kits. Maybe its just a error on their site.
edalfa
Shovelhead
May 30, 2018 12:25 PM
brakes
Jul 15, 2017 11:07 AM
glarior
Jun 3, 2017 06:27 PM
shovelshort
Wheels/Tires
11
Oct 15, 2012 08:14 AM
shiftless
Wheels/Tires
Jun 13, 2009 08:58 AM
