Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Fork Oil Disposal/Recycling Question
Old May 13, 2024 | 06:15 PM
LQQK_OUT's Avatar
LQQK_OUT
Question Fork Oil Disposal/Recycling Question
Can one mix in the same container both used engine oil and used fork oil for proper recycling and disposal? I have a 5 gallon (gas) container that I use to hold my used engine oil. When the container is full, I take it to the local auto store to dump into their 55 gallon drum of used oil. I know you're not supposed to mix brake fluid with the engine oil. What about fork oil? Can I also mix it in the same 5 gallon contain with my engine oil to take to the auto store to dump out?
Old May 13, 2024 | 06:23 PM
gonemad's Avatar
gonemad
All they tell me is no antifreeze. Judging from the folks I see in and out of my three part’s houses close by, there’s no telling what all ends up in those oil containers for recycling.
2017M8's Avatar
2017M8
O Reilly's has no issue taking my oil mixtures,, just no gas or Rad Fluid mixture
Old May 14, 2024 | 09:04 AM
multihdrdr's Avatar
multihdrdr
You're good ... dump it already
Old May 14, 2024 | 02:06 PM
KK0G's Avatar
KK0G
Who says you can't put brake fluid into waste oil? At work we put engine oil, hydraulic oil, ATF, brake fluid, gear oil, refrigerant oil, compressor oil, diesel fuel, etc. into our waste oil tank, been that way for decades. You're fine.
Old May 14, 2024 | 02:47 PM
MCRD'71's Avatar
MCRD'71
Don't go all maryfornia on us. Pour it in with the other oils.
Lars_Danner
Jun 7, 2023 10:11 AM
wiseguyups
2014-2024 Touring Models
Dec 10, 2019 07:34 PM
valpal
Jul 15, 2016 04:25 PM
Am4wag
Sep 15, 2014 02:43 PM
BiggDogg
11
Aug 30, 2010 12:45 AM
