Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Springer conversion
Old Jan 13, 2025 | 05:13 PM
JayTee433's Avatar
JayTee433
Stage IV
Default Springer conversion
I have a 2015 softail slim, I’m wanting to convert front end to a springer. All springers I have looked at have 3/4” axles, is it ok to run 3/4 axle in front and 1” in rear? If not what are my options for running a springer with stock 1” axle? Thank you, this is my first time asking a question sorry if I sound dumb.
Old Jan 13, 2025 | 05:31 PM
TexasScooterTrash's Avatar
TexasScooterTrash
You need to know the diameter and length of the lower tree stem to be sure if it will fit your frame. No clue as to what front wheel ya wanna use. IF a wheel has 1" axle bearings, ya gotta change em to 3/4" bearings to work.
Old Jan 13, 2025 | 05:52 PM
JayTee433's Avatar
JayTee433
Stage IV
right on brotha, i was gonna throw on a 84-99 wide glide wheel, i was just concerned about downsizing the axle diameter from the stock 1” to the 3/4 safety wise.
Old Jan 14, 2025 | 06:53 AM
eighteight's Avatar
eighteight
[QUOTE=JayTee433;21915997, i was just concerned about downsizing the axle diameter from the stock 1” to the 3/4 safety wise.[/QUOTE]
100% Non issue.
Old Jan 14, 2025 | 08:12 AM
KK0G's Avatar
KK0G
Yes.
Old Jan 14, 2025 | 09:13 AM
bustert's Avatar
bustert
what does 1" rear and 3/4" front have to do with anything. shoot with the right materials, you could run 1/4". do not get your panties in a wad, just rhetorical jest!!!
hummmmmm
Old Jan 14, 2025 | 10:05 AM
JayTee433's Avatar
JayTee433
Stage IV
hummmmmm
right on man that’s why I’m on here trying to learn. Thanks bro
Old Jan 14, 2025 | 10:07 AM
JayTee433's Avatar
JayTee433
Stage IV
100% Non issue.
Thank you man
Old Jan 22, 2025 | 09:49 AM
Harley_ish's Avatar
Harley_ish
Slightly late, but just Fyi, your original axle size is 25mm (not 1")
Bigwillie
The General Motorcycle Forum
Jan 2, 2025 03:18 PM
PurpleShark
Oct 23, 2022 09:39 AM
ESEMCparts
General Topics/Tech Tips
Aug 8, 2015 09:28 PM
bikerlaw
May 26, 2010 09:32 PM
EvilWayz
Ironhead
Apr 25, 2010 11:27 AM
