Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Air shock service question
Old Dec 11, 2025 | 05:04 AM
eighteight's Avatar
eighteight
Default Air shock service question
O.E. air shocks
Watched the videos
Drained the shocks
Cannot refill using the Mity-vac method
I assume you can`t push new oil in because the air in the shock cavity has no place to escape ?
What am I missing ?
Thank you
Old Dec 11, 2025 | 05:43 AM
chopper_man's Avatar
chopper_man
What about collapsing the shock, connect the oil supply, then expand the shock and suck it right in?
Old Dec 11, 2025 | 07:08 AM
touchdown's Avatar
touchdown
Put them in the trash, they are junk. someone has a nice set of Bitubo's for sale on this forum for 400 but everything is negotiable.
Old Dec 11, 2025 | 08:39 AM
bustert's Avatar
bustert
do you have the vacuum port on the correct side?
aka, pulling vacuum on the shock through the down tube of the container, allowing the fluid to be pulled up into the shock. any air leak will thwart the process.
oem bad???
beauty is in the eye of the beholder. mine are 25 years old and fully adjustable and still works like a charm and are OEM and made by showa, to boot are rebuildable.
Old Dec 11, 2025 | 09:05 AM
eighteight's Avatar
eighteight
Yes, it is plumbed correctly
No leaks as it will show 20 inch of vac
hardheaded
Aug 12, 2024 04:59 PM
nanook
2014-2024 Touring Models
Apr 18, 2017 05:11 AM
jeemann99
Apr 4, 2015 11:40 PM
jcanrun
Jan 13, 2015 12:20 PM
harleyflo
Jan 30, 2009 02:04 PM
