Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Help!!!!!!! frontend alignment
Old Aug 26, 2006 | 09:59 PM
HaramiHoBo's Avatar
HaramiHoBo
1st Gear
Default Help!!!!!!! frontend alignment
i had to laydown my bike to miss a taxi (ride'in in istanbul is crazy) and slid into him when i picked up the bike i now see when the front wheel is straight the bars are not. the handle bars are bent but the front end is also out of align how do i adjust it i looked at my manual but it is not covered and livin in Turkey doesn't give me alot of service choices!! plus i would like to do this stuff myself ( with your help ofcourse) i ride a 2000 flstc with a stock frontend
Thanks in advance
Haramihobo
Old Aug 27, 2006 | 12:27 AM
bobcowan's Avatar
bobcowan
Default RE: Help!!!!!!! frontend alignment
There's nothing to be aligned, and nothing that can become out of alignment. However, there's lots of things that can be bent. Usually requires replacement.
Old Aug 28, 2006 | 09:28 AM
rh8234's Avatar
rh8234
You can loosten the pinch bolts on the tripple trees and give the handlebars a few shakes. Sometimes when you lay it down the fork tubes twist a little in the trees. If nothing is bent you will probably be able to align things by loostening those pinch bolts. Also, it's possibe that the risers got a little misaligned. Loosten the two riser bolts and realign the bars.
Old Aug 29, 2006 | 03:03 PM
HaramiHoBo's Avatar
HaramiHoBo
1st Gear
Thanks rh8234 finally somone without a dooms day attitude i'll try it and let you know what happens
Thanks again
Old Aug 29, 2006 | 03:19 PM
rh8234's Avatar
rh8234
I've been down that road myself. I let a friend take a ride and when she hit the pavement at about 45 MPH, my fork tubes twisted in the trees. I thought they were bent, but I licked out.
Old Aug 29, 2006 | 03:24 PM
HaramiHoBo's Avatar
HaramiHoBo
1st Gear
İ was only doin about 10 so i don't really think anything is bent (rely'in on a little biker karma) we will see tomarrow
Thanks again
P.S did you really lickout[sm=lildevil.gif]
Old Aug 30, 2006 | 11:25 AM
rh8234's Avatar
rh8234
No, I didn't get much licken in that day. To many people in the emergency room. I "lucked out" with the bike, but the lady riding my bike didn't fare as well.
goose222
2014-2024 Touring Models
Jul 25, 2015 06:27 AM
Stamas31
Jan 6, 2015 03:22 PM
Momentor
Sep 10, 2007 07:25 PM
85RoadsterXLS
Feb 17, 2007 11:34 AM
edsaws
Sep 4, 2005 12:28 PM
