Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
oil on disk pads
Old Nov 20, 2012 | 03:01 AM
fxrmite's Avatar
fxrmite
Stage I
Smile oil on disk pads
Hiya all
I recently trailored my FXR.
On the way there I anchored the ratchets to the handle bars and upper fork area. (unfortunate)
On the way back, I anchored the bike lower down on the forks.
I now have oil leaking all over my brake disks. I have wiped the oil off several times but the pads are so soaked that the disks themselves become soaked.
I have two simple questions -
one regards safety when riding the bike in this condition;
and the other regards operation clean-up.
Any comments/thoughts/suggestions would be appreciated.
Thanks
FXR-Mite
Old Nov 20, 2012 | 06:49 AM
xwhyz1959's Avatar
xwhyz1959
Greetings and welcome to the forum. Firstly, have you determined the source of the oil? Second, I wouldn't ride it in that condition for sure!! You need to remove the pads and hose them down repeatedly with brake cleaner to get all the oil off of them. If you leave any oil on them, it can over time lead to uneven rotor wear. Ihad to replace a rotor for that very reason.
i
Old Nov 20, 2012 | 08:02 AM
JohnnyC's Avatar
JohnnyC
Sorry to hear you lashed your ride down for trailering the wrong way and caused damage.
Let's see fork seals bad, leaking oil onto front brakes.
I'd say it's very unsafe and would not ride until I fixed the leaking forks and thoroughly cleaned the brake assembly.
I would consider replacing the pads after cleaning up all of the oil. Odds are if you rode it at all that way the pads are deeply contaminated and may never be right, even with a cleaning.
itznin
Jun 21, 2011 11:08 AM
irondog
Shovelhead
Jun 21, 2010 08:18 AM
logdon17
May 2, 2010 02:36 PM
Solidworksguy
Sep 6, 2009 05:56 PM
bradteed
Jan 28, 2007 12:44 PM
