Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
2006 Ultra Classic
Old Jun 2, 2013 | 02:09 PM
chris stallings's Avatar
chris stallings
Stage I
Default 2006 Ultra Classic
My brother-in-law recently purchased a 2006 Ultra Classic with about 5000 miles on the bike. The owner just didn't ride it very much and decided he wanted to sell the bike. My brother-in-law said that the bike pulls hard to the left and it is a struggle to turn to the right. I'm looking for any suggestions that might be causing the problem.
I asked him if the bike had ever been wrecked and he said the owner said no, just dropped once.
Any thoughts/suggestions will be gladly welcomed.
Thanks!!!!
Old Jun 3, 2013 | 12:48 PM
dacula951's Avatar
dacula951
Does the handlebar seem to be straight when the front wheel is straight ahead? Perhaps it has a bent fork tube from a bump to the front wheel.
Old Jun 3, 2013 | 01:50 PM
ZUTEDUFF's Avatar
ZUTEDUFF
might be a stuck caliper on the left side front...I guess the struggle to turn to the right is moving and not setting still....if setting still, got a problem in the head bearings I would think...
Old Jun 4, 2013 | 12:31 PM
grbrown's Avatar
grbrown
Chris, welcome to HDF from the UK. It is difficult to answer secondhand questions! Have YOU ridden it? It would help us to answer comments you make from firsthand experience, or get you bro to join, so we can get it from the horse's mouth. You seem to be suggesting the bike is not safe to ride. At the least, if neither of you are able to identify why, get it checked over by a local indy or dealer. We can't see it or ride it over the internet!
The things you can check easily are if either wheel is dragging: jack each wheel up and turn it over by hand, also twist each of them from the side, to see if the bearings are OK. With the bike on the ground check wheel alignment using a straight edge of even a piece of string pulled tight, to see if they are in line with each other.
Let us know what you find.
JJHOG
Dec 15, 2012 02:04 PM
lmb1485
Dec 29, 2008 10:42 PM
smizzz
Sep 24, 2008 04:26 PM
Nach
Jun 1, 2008 10:24 AM
brighton
EVO
11
Aug 28, 2007 10:24 PM
