Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Rear brake problem 1999 FLHRCI
Old Feb 17, 2014 | 11:59 PM
Roadking Cal's Avatar
Roadking Cal
Default Rear brake problem 1999 FLHRCI
HELP!
I'm having a real problem here...
The rear brake will not pump up. I've bled the system
With DOT 5 fluid, replaced the pads, and bled
The brakes a second time. There are no
leaks evident anywhere, and it appears to be
Able to push fluid just fine when bleeding.
I'm stumped. Any suggestions would be helpful
Thanks!
Old Feb 19, 2014 | 03:55 PM
grbrown's Avatar
grbrown
Go to the Frame/Brakes section where you will find a couple of Stickys to help. You need to take a deep breath, prey to all your gods and persevere! There are many instruments of torture available that claim to help, which you may find helpful. You will also find plenty of other pleas for help, with suggestions.
hel69
11
Sep 23, 2017 01:48 PM
Dudepants
Apr 30, 2017 10:26 AM
chrome one
EVO
Nov 14, 2010 02:27 PM
tominokla
May 3, 2007 09:57 PM
PoCoBob
Shovelhead
Apr 14, 2007 08:50 PM
